Finally got around to putting some car builders under bonnet stuff on, basically to camoflauge the chop chop a bit
I do need to replace the windscreen squirter hoses though as they have hardened up
Before
After
Fully stock now.....
  • Like 5
Consumers will consume, I pulled the pin on something for the Honda I said I didn't need, but meh, a PLM header, comes with a decat
The decat pipe will get the cat chopped into it
This basically optimises the exhaust now for NA duties
PLM-PCD-14-2T_15d4132e-05c4-4755-a99e-ce8cb2504c96.thumb.jpg.7dc660223f0ee35550e57e627e38d078.jpg
Express shipping so should be here in under a week
But probably not as it is coming via Australia Post from QLD, so could take a month
But apart from this, the Honda is staying stock....
  • Haha 1
So when fitting a g35 1050 and quaife sequential??
The bogan cruise ship going to modded any further?
Keep an eye on here for drag and drive event
https://www.facebook.com/groups/314009295848803/?hoisted_section_header_type=recently_seen&multi_permalinks=1104579606791764
  • Like 1
I'm happy how Bogan Cruise Ship is, so just maintenance and the assumed broken bits now and then
As for the Honda, if, when, the clutch goes it might get a LSD (while we're in there), apart from that it will remain "stock"
I keep trying to spot them when driving around, I think "there's one", but nope, they keep turning out to be Toyota Camry's 🫣
  • Haha 1
Big difference between the stock pressed and welded steel header pipe and the cast aftermarket one in relation to smooth flow
Plus the OEM header isn't matched to the head or gasket, whereas the aftermarket one matches the gasket and head
  • Like 1
Took the Bogan Cruise Ship to Goulburn to visit the daughter for 2nd breakfast and lunch, car was a pleasure cruising on the Hwy
The kid has grown up and is adulting like a boss
I miss my "little bunny rabbit" who only had time for her dad, now it's all "I have to go to work now dad" (NSW police).... proud dad is proud
I believe my parenting superpower was letting her watch me do dumb shit, and her learning from that of what not to do
In saying that, her Xmas present, that she asked for, was a cat back for her new Kia Cerato GT hatch, that did put a smile on her face when she took it for a drive after we fitted it
  • Like 2
Gave the Bogan Cruise Ship some love IRT paint
As there is no one really at work I had easy access to the wash bay, and undercover parking
1. Truck wash and hot water pressure washer to clean off most the old wax and sealer
2. Then some Chemical Guys clean slate to clean off what the truck wash and hot water pressure washer missed
3. Then 2 coats of Autoglym ceramic coating
I'll give it a day for the ceramic to cure, then hard wax it
Whilst the ceramic leaves it nice and shiny, I find a good wax will give it a deeper look to the paint, I also find the wax also protects the ceramic coating as a sacrificial layer
I'm basically preparing it for all the ash from the bushfires that will probably happen over the next month or so, and the hot water pressure washer at work makes short work of removing old wax when required (every couple of months)
As for the Honda, I finished painting the stock rims, they had some hectic scratches on them, but, am I happy with how they turned out, not really, but, they are much better than they were
Also, the new header and front pipe on the Honda is all V-Tec YO buzz box noises now when it gets given the beans, it is though surprisingly  quiet still when cruising around, whilst the Honda ain't fast, it is fun as a fuel efficient daily hack
  • Like 2
Major issues apparently with the noises the Honda makes now, Jackie has decided that the Honda is to "buzzy" when she is giving it the beans heading to the shops (the Honda is like the town bike for the family, everyone takes it for a ride) so I have a incoming resonator to keep the Minister of War and Finances happy
From the Google's the Vibrant 1140 will slip over the stock pipe for a easy fit, will knock out most of the buzz, and there is adequate room for it in the OEM midpipe without any clearance issues with the floor or ground clearance
I liked the bit of buzz at higher rpm as I felt it suited the Honda 4 cylinder V-Tec YO sound, but, you got to keep the better half "reasonably" happy I suppose
It gets its tune early Feb when Chongie heads down from QLD
56 minutes ago, Kinkstaah said:
K20 > MX5 BP1.8/LS1/RB
Logical fallacy cannot be processed. There is no world in which a 4 cyl engine sounds better than a straight 6. Especially one that sounds like an RB.
I mean, I had an ALFA 2L, with better carbies, ram tubes and sock filters and a great exhaust and I thought it sounded awesome. Which it did. For a 4 cyl. All borty. But it was nothing compared to 7500rpm in the Skyline.
I see your straight 6 RB and raise a 4AGE 20v with ITB reving over 10k rpm
Took the Cruise Ship for a cruise on Sunday, all was well until I headed down Bulli pass, brake fad was was interesting to say the least, I made it down without incident, but, the front right disc was blue/black and the caliper was smoking like a champion
After letting the brakes cool down we "gingerly" headed home at a extremely leisurely pace avoiding hills, luckily were at the bottom of the mountain and the brakes regained some bite for the plod home
At home I jacked up to find a seized front left caliper, the pistons are FUBAR from rust and the seals are also questionable
So, as I do, it is time to use my typical approach to things
I've ordered new:
Front and rear calipers (OEM)
Front and rear discs and pads (DBA street series), which by good chance were currently on special at SCA
And also new some new OEM front wheel bearing assemblies...... #while were in there..... (I'm assuming the front wheel bearing didn't like being at 11ty million degrees, and for a couple of hundred to replace it is a no-brainer, good thing the Commodore parts are cheap as chips to replace, and plentiful)
The Commodore has now been put to bed until all the bits and pieces arrive
  • Like 1
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
