I've seen a couple of these dashes in person, all with the same very poor quality. Laine @bcozican will know....
This is not how a 3D printed part should look though. A properly 3D printed part will look good. These guys either have absolutely no idea what they are doing, or they are using a very poor quality printer. To me, I think they are using way too high a stepover in order to save time on each print. Which tells me their printer isn't up to the task of the production environment they are going for. Also the edges not being straight indicates the prints are warping, which again points to either a rushed print or cheap materials. There is serious refinement needed before these things are ready for production.
  • Like 1
6 hours ago, DaymoR32 said:
Thats because the images on the website arent photos but 3d renders spat out by solidworks/fusion 360, everything looks better on CAD.
I belive there is actually a way now of spitting out the sliced file (essentially gcode for the 3d printer) putting it back into the cad package and then being able to render it - showing how it would truly look once printed with all the layer lines etc..
Fusion 360 will show you a simulation of the machined/printed part in the CAM workspace just by default. I haven't used Solidworks, but I imagine it will be the same.
Yeah I don’t use fusion myself, used solid works daily for the past 10 years. Understand you can do CAM for machining but don’t think the 3D printing part profiles are there yet (well not in solid works anyway).
i do agree with the part quality, they are probably printing around the 0.3mm layer height to get the clusters out in roughly 6-8 hours. Soon as you go down to 0.2 or 0.1 you are massively increasing production times.
still at $200 odd for a cluster you should be able to justify the longer time. It’s not like they’ll be using heaps of filament, electricity won’t be much either. The cost is probably in the design time and possibly in the machines
My cluster was $407 =/
Does anyone know if the 3dracingsolutions stuff is any better?
Wow.. mine was 200 odd and i wasnt happy for the level I wanted for my car so on sold it
Horses for courses - not great and super clean but can see the appeal for people as an easier and reasonably decent solution for those that dontwant to pay for custom or have the know how to make it work otherwise
Well here we go again.
I sent the wrong dash back, new dash arrived today.... With the wrong LED light. They sent a blinker indicator instead of a battery light.
And unless I'm completely retarded, I can't see how it would be secured as the nut is a long way from reaching any threads.
I hope so. I haven't trial fitted it yet.
I still haven't setup the ECU to receive the fuel level signal yet as my in tank fuel level float thing has fallen off again on my last track day. Can't wait to dig around in the fuel tank again and put it back in it's slot.
  • Like 1
  • 3 weeks later...
Nice :)
If you get a chance while your installing it, do you mind doing a little how-to on how to wire the battery light resistor?
I don't know why I can't get my head around how to wire in the resistor where the battery light was.
But reading online, isn't there a red and white cable that is around 9V that you would just add the globe too?
I'm using a resistor, I'll link to the instructions below -
https://cdn.shopify.com/s/files/1/0059/8332/files/Alternator_Excitor_LED_Module.pdf?2740344812066901986
I guess I'll just wire the "Blue - To Alternator Switch" to the charge light and see how I go.
Photos from my car that runs an IQ3 Haltech dash. Was installed prior to me owning it.
there’s a white with red trace and a red wire that have been cut into and now power a globe. 814187CF-66B8-4B5F-A224-EB4108D6CC59.thumb.jpeg.1323b7093476ad3022cdd84037b27d5f.jpeg
When you flick the ignition onto accessories the globe lights up. Once you start the car the globe goes out.
  • Like 1
@Murray_Calavera
how did you get around the central locking control unit issue? Just realised I can’t lock my car unless the battery is disconnected as there is a central locking control unit in the cluster. When I go to lock the door the motor tries to keep the door unlocked.
also for the Speedo they needed to wire the gearbox speed sensor to the factory inputs in the Haltech otherwise you won’t get any speed readouts. Turns out from factory the speed sensor goes to the dash first then the ecu....
Edited by Tobz
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
