Unsure if this is the right forum to post under..
I'm looking for opinions on whether I would be better to go 20de +T or put a 25 cam into it?
My friends said 25 cam, I personally want a turbo but can't do both due to high compression?
This probably makes no sense. (Sorry) just very confused.
https://www.sau.com.au/forums/topic/480604-help/
17 minutes ago, JordanRochelle said:
Sorry, 25 cam shaft?
changing the cam to any possible other cam in an RB20 is a total waste of time and effort. Turboing an RB20 is also a waste of time as the result will be disapointing.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933087
Why disappointing? I've seen plenty of 20de+t that go hard... I'm not chasing power or huge numbers. Just something fun
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933577
2 hours ago, GTSBoy said:
They only go hard above 5000rpm. Everywhere else they suck.
This ^^^^^
Having previously owned an RB20DET with a few mods and now having a RB25DET NEO
the difference lower down in the rev range is massivley noticeable
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933605
Honestly...sell that rolling wreck for whatever you can get for it.
Buy a going RB25.... if you have to.  Otherwise just about any other car will do till you get off your P's.
Reason, adding a cam is a waste of $$$, changing the motor to an RB25 makes more sense, but is a costly and ultimately futile build.
Plus by the time you cut out the rust, redo the window seals, fix up the front end, upgrade the brakes, suspension, and other stuff, you are up for big $$$.  Buying an RB25 with all this stuff done and then setting out to improve it even more will cost much less and also  - in the end - be a better car.  Plus side of a 25 is what you take off can be resold.
The only possible reason for continuing with that RB20 is you are starting with a 'blank canvas', but its 12 months to 3 years of hard yakka getting it done.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933606
I'm in NZ so don't have the issues on Ps etc..
I have all the parts of this body, the body is straight no rust anywhere.. I just want to keep my 20de cause I have it torn down ready for rebuild. I can get a full rebuild kit cheap asf cause my partner works in parts. Could also get a det block too but I'm just not sure.
I don't want to put the 25 cam shaft into it, I'd rather get a det block or a +T but the boys reckon a 25 cam would be better ??‍♀️
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933882
so they think an RB25 Cam (assume you are talking inlet only, there are 2? ) in an RB20DE is better than either an RB20DE+T and an RB25DET?
thats potentially the most retarded thing I have read on here in a while. Even with the best camshafts in the world (2 of them) in an RB20DE it is still a heap of shit. even rebuilt.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933886
And just to hit this one again....the difference between the 20 cams and the 25 cams is so small that the time, money and effort spent on the swap would be better spent buying 6" railway spikes to hammer into your own skull.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933889
The boys at the local kindergarten?  Can they tell you how it is different (and I can tell you that as GTSBoy says its SFA) and what difference it will make?
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933914
Good on you for resurrecting another Skyline.
Looks like a big project. If you are in for the long haul, and if I were you, I would look at getting the 20det bock, pistons turbo and build it from the bottom to top. I am not too sure that is all the differences. But do your homework and calculate what it is going to cost, then double it. A good 20det screams nicely.
Good luck.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7935147
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
