Just putting it out there, interested in hearing peoples thoughts on this.
For a GTR with where they are going and with ‘purity’ possibly becoming more important nowadays.
would you prefer a 26 based bottom end or a 30 based bottom end?
and why?
purely for discussion, let’s not go to war over this! Lol
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/
For a motor that will feel better everywhere in all usage models, a 30. Every time. The only way that it is let down compared to a 26 is that elastic need for revs and the extra little buzz you get from running to 11ty rpm. But I'd rather more torque and power everywhere.
Put the 26 block in the shed for later purity restoration.
Although....in a 32, I am against the shitty mods you have to do to squeeze a 30 into the engine bay.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944070
3 hours ago, Stixbnr32 said:
Yeah if i was to do my build again id still go 26 block in my R32 but id prob go a nitto 2.8 stroker.
Everything fits under the bonnet and you get a decent bump inpower/torque.
I would also use a PRP brace.
THIS. I kinda regret doing a 3.2 mainly due to fitmet issues. I just hate chopping shit up, but thats just me. I'm sure when mines running it will be well worth it, but if i was to do it all again, I'd def do a high revving 500kw 2.8.
  • Like 1
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944129
Cheers for the responses, looks like a 26 based bottom end wins the popular vote.
To ‘let the cat out the bag’ I’ve been considering building a bottom end and was undecided which way to go.
My car is currently fitted with a 30 bottom end.
anyway, the opportunity has come up to purchase a JHH built 2.7 motor, built in an N1 block with their Raceport head package.
My reservations are, my current setup is so good, torque everywhere, good response and fast enough for me, but this set up isn’t where I’m going with the build. I want a 26 block, but I’m nervous I won’t like it compared to what I currently have.
the struggle is real! Lol
  • Haha 1
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944133
1 hour ago, Predator1 said:
If you already have a 30, then stick with it. 2.7 will see a noticeable amount of lag, plus you might need a smaller turbo.
Depends on what you really want at the end of the day. How much power does your 30 make atm?
Car make 440kw on 98 @ 20psi
and 580kw on E85 @ 32 psi
Obviously the powerband will move up the rpm range in the 2.7, but the 2.7 will happily Rev to 9500rpm and the 3.0 is restricted to lower rpm.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944137
5 hours ago, GTSBoy said:
I dunno man. You've already done what's needed to put a 30 based engine in. The damage is done, the pipework is set up.
At your power level you're really going to feel the difference if you drop 10% capacity.
That’s where I’m stuck, the 30 is in and is a great motor. Was built well, but a part of me really wants a 26.
then on top of that, I’m nervous I’m going to be disappointed.
AND at some point, I will be going back to a 26 block, just this opportunity has come up now and I was hoping to enjoy the current set up for a few years first.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944162
This is me, if I was building a motor, then I would build a 2.7/8. The 30 was in it when I bought the car, but it’s proven to be a very good motor. So now a part of me says stuck with what you got, you know it’s good, it’s set up and it works, and the other part says, build it how you want.
Now it seems from the responses here that most, if building from scratch, would go with a 2.7-2.8 over a 3.0/2
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944181
The torque of the RB30 is real. My mates 32R makes 440~awkw @ only 18psi with no timing, and that thing had virtually no lag. Even going uphill, that thing would just haul from any gear/revs. In contrast, a 2.6 or 2.7 or eve a 2.8 would see considerable lag before it starts to boogey. IMHO, stick with what you have, and enjoy life.
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944182
Another thing, guys who have gone from a standard crank to a billet crank, how much difference does it make? I’ve read that the billet Rev much smoother/quicker and feel very sharp on the throttle?
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944183
Yeah I hear you, this is my car now, even with the 68/70, it’s on when you roll the throttle, rpm doesn’t really matter. As a street car, it’s probably as good as you’d want, but because I’m a little weird I think ‘As a GTR’ where do I want it?
shouldnt a GTR have lag, isn’t that part of the driving experience, lol
If I do this, it won’t be one engine out and one in, it will be engine bay respray, blast and coat subframe, replace bonnet, re wire engine bay. I will bring the bay up to a standard I want it. It presents well now, but It’s no where near finished to a level I’m happy with.
But thanks for the the input, I appreciate peoples opinions on this, helps to give perspective and give me an idea what to expect if I move forward with this.
  • Like 2
https://www.sau.com.au/forums/topic/481613-rb26-or-rb30/#findComment-7944184
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
