Hey!
So I've been swapping my head bolts to arp2000 studs all has been going great till I got to the front of the engine. For noting I am doing this with the cams in the engine and want to confirm there isn't some  magical trick to do this without removing the cams.
Basically at the front of the engine the gap between the cams and the head is too small to fit a 5/8inch socket. The old head Bolt removed fine, the new stud went in fine, washer and nut all fine. Just can't get the socket in. Just wondering if anyone has any hints or tips, or if I just need to bite the bullet and remove the cam?
Cheers for the help
Toby
https://www.sau.com.au/forums/topic/481736-head-bolt-access/
Damn thing, need to make another, needed it for the four corners. Got all 4 to 60ft pound, them on the final 90ft pound torque it snapped on the second one. So need to make another for the final 2 bolts
Edited by Tobz
  • Like 1
I had the same issue, but couldn't get to any of the nuts. Ground the crap out of the socket, luckily mine didn't break.Then bought a cpl of superslim sparkplug sockets; they only fitted on the middle studs - still wounldn't fit at either end, very tight fit alright...the ground-down socket barely fits and only fits in one position. Thats with tomei cams.
With the standard cams I and no issues using a 3/8inch 5/8th socket as they are pretty slim. And then needed to ground down the socket for the corners... Hopefully I can finish the last two tmrw with just one more socket :)
but pretty happy to have it almost done!!!
  • Like 1
if you don't have some cut up twisted, grinded, or bent wrenches and sockets collecting in your shop your car either runs really good or you have a mechanic lol. Most my wrenches end up grinded or bent up in some way along the line to fit just right in wierd places on weird skyline jobs. hope the job goes well mate get that boost cranked up mate.
  • Like 1
Got it all done! i have to say i was super worried about snapping a stud or bolt in the days leading up to it, as usually its easy enough to remove and either retap or ignore completely. But with this if anything went wrong it meant taking the head off at a minimum.
Anyway first two I did i felt like I was undertaking open heart surgery. Torquing the bolts seems unnatural to put so much torque on such a small nut. But after the first two i wasn't worried at all and got into a good little rhythm.
Then i got to the corners, wasnt too worried, came here for help, got some awesome advice, continued the job and got it done with no issues. Overall was a fairly simple job!
Super happy its done though, also really happy i invested in a good quality digital torque wrench last year, really makes a huge difference!
  • Like 1
1 minute ago, Dose Pipe Sutututu said:
You skip a few heart beats when it makes these creaking noises too haha
I almost had a heart attack with i snapped the shaved down socket on the back of the head....  then i remembered it was more likely to be the dodgy socket i created than the head bolt...  was so relieved when i saw the socket snapped!
  • Like 1
  • Haha 1
I must say, when looking back at it, doing head studs/nuts with the motor still in the car is quite amusing as you're in an awkward position!
Doing it on an engine stand, right next to you feels more natural.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
