Hi everyone, I have had trouble with the car since I got it (2002 m35 VQ25DET) it seems to get air into the system somehow after just installing a bleeder as someone previous broke mine and bled it properly finally after replacing thermostat and radiator. On a inclined driveway was bleeding it and seemed fine held temp nicely and drove for 5 minutes floored it once and then finished going around the massive circle, and after flooring it about 3 mins later it starts to go up in temp from dash then aftermarket goes up fast.
Then once it's on and and have returned home I loosen the bleeder and all this hot mist and air comes out was coming out for about 5 minutes, but before hand there was no air in it.
Since I've got it it overheats then pisses out coolant and steam out of overflow even after the replacement s of thermostat and radiator, and then bleeding.
It's currently on 12 psi. My father says it could be air from the turbo and it's leaking through a gasket into cooling system... But I thought I might ask the experts here.
Please help me 😳
Not an expert on bleeding air, but I have jacked a car up. Loosened the highest point coolant hose, which was on this model, not a skyline.
The hose that went into heater matrix.
Could actually hear the air escaping, then coolant, tightened up hose! Sorted.
use a funnel/cut down coke bottle at fill point, car running and also heater on full. will take a while but will bleed up, I have found using one of these the best for actually bleeding cooling systems
one other thing could be a blown headgasket.........
Ye, this is also a symptom of having combustion gases (not turbo boost, but still sorta kinda boost in a way) in your coolant. Typically through a gasket but in my case it was through the block 😮
I recently bought a rad cap funnel kit and oh man they are great. Should have been the first tool I ever bought.
Try the Stagea M35 section mate.
The M35s are a nightmare to bleed. There was even a bleeding kit created by Scotty, that was using an addiitonal bleed point in the valley, as used by the VQ40 in the Pathy.
It does take hours to do it properly.. I know this from when i had the rad in my M35 replaced.
12 hours ago, GTSBoy said:
More likely it wasn't actually bled the first time. You don't want to hear it, but it's almost certainly the case. Got a bleeding funnel for the rad cap?
It wasn't bled when previous owner change the coolant 400 KMs before I bought it, when he took me for a 30 min drive he turned the heater on full ball and it cooled down straight away... But it doesn't work for me at all and between then and now I've replace thermostat and radiator so more air in the system...I am currently doing it again but putting nose down hill not up hill this time. I wish I could have bled it, but had no bleed screw so had to buy one.. no I don't have bleed rad cap.
Edited by I agree
There is quite a chance that running it with a large air pocket in it has overheated something and done the HG or cracked something, per what the others have said.
The bleeding funnel I mentioned is not a bleeder on the rad cap. It's a funnel that goes where the rad cap is, to increase the head height of the rad to help get water in and air out. Makes the highest point in the system right up high above the rad cap. Same as the cut coke bottle mentioned above. Needs to seal in the rad cap throat fairly well though, otherwise it won't work.
you telling us it overheated on the test drive, and you with no mechanical knowledge decided to buy it anyway?
I didn't buy it...I swapped it for my mr2 Spyder that got hit by a truck (hit and run) and had a bent chassis and damage all over the car and day after being hit, was caught in the massive Springfield storm and came through the roof of the cars and hit me in the head and had 2 seizure after that, it was a write off bad had no insurance, we swapped it as he wanted for parts... And was a driving defect after all that.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
