Since i've removed the water heat exchanges on my RB26, I was contemplating on adding a small oil cooler. Can anybody vouch for the effectiveness of a smaller Setrab unit like this or this?
They're around 8x4-5 inch 10-13 row but I'm not interested in adding anything larger around the front bumper wheel well area. I'd rather keep it compact.
The setup is not a race car but a street car with repetitive high RPM reaches.
https://www.sau.com.au/forums/topic/481910-small-oil-cooler-effectiveness/
16 minutes ago, Murray_Calavera said:
Do you have an oil temp sensor/ECU or a oil temp gauge? What sort of temps are you seeing at the moment?
Not running hot at the moment and piecing a single turbo build. Wanted general consensus around this setup based on experience
It really is hard to provide advice because it depends on how much you are trying to lower temps, and at this stage you don't know if you have a problem at all.
I'd go without an oil cooler for now, but add a temp gauge. My guess is something that small won't make much difference so would only be useful if you have a minor temp issue
I've got a Series 6 25 row setrab in a nismo duct and on the track oil temps still get to 120 degrees after 5 laps.
on the road im not sure I'd bother. definitely put a temp sensor in and if you are getting over 100 degrees move to a decent synthetic oil then keep it under 120 degrees.
if you can't keep it below this, then spend the money on the cooler.
Edited by burn4005
  • Thanks 1
This is good advice. The only thing I would add is always use synthetic oil in a turbro.
Pretty much all of them have thermostatic plates for above 80C or so (which is technically a bit low)
If you actually get your oil on the street above 120C then a bigger concern is not dying/going to jail.
LS yes
RB no
Get a gauge to find out how hot your oil is/how hot it gets before buying something to address an issue which may or may not exist.
Generally speaking, if you want an oil cooler you want it for the track, so fit the biggest one you can physically fit and move everything else out the way to fit it.
Any other use generally requires no oil cooling.
  • Thanks 1
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
