Since i've removed the water heat exchanges on my RB26, I was contemplating on adding a small oil cooler. Can anybody vouch for the effectiveness of a smaller Setrab unit like this or this?
They're around 8x4-5 inch 10-13 row but I'm not interested in adding anything larger around the front bumper wheel well area. I'd rather keep it compact.
The setup is not a race car but a street car with repetitive high RPM reaches.
https://www.sau.com.au/forums/topic/481910-small-oil-cooler-effectiveness/
16 minutes ago, Murray_Calavera said:
Do you have an oil temp sensor/ECU or a oil temp gauge? What sort of temps are you seeing at the moment?
Not running hot at the moment and piecing a single turbo build. Wanted general consensus around this setup based on experience
It really is hard to provide advice because it depends on how much you are trying to lower temps, and at this stage you don't know if you have a problem at all.
I'd go without an oil cooler for now, but add a temp gauge. My guess is something that small won't make much difference so would only be useful if you have a minor temp issue
I've got a Series 6 25 row setrab in a nismo duct and on the track oil temps still get to 120 degrees after 5 laps.
on the road im not sure I'd bother. definitely put a temp sensor in and if you are getting over 100 degrees move to a decent synthetic oil then keep it under 120 degrees.
if you can't keep it below this, then spend the money on the cooler.
Edited by burn4005
  • Thanks 1
This is good advice. The only thing I would add is always use synthetic oil in a turbro.
Pretty much all of them have thermostatic plates for above 80C or so (which is technically a bit low)
If you actually get your oil on the street above 120C then a bigger concern is not dying/going to jail.
LS yes
RB no
Get a gauge to find out how hot your oil is/how hot it gets before buying something to address an issue which may or may not exist.
Generally speaking, if you want an oil cooler you want it for the track, so fit the biggest one you can physically fit and move everything else out the way to fit it.
Any other use generally requires no oil cooling.
  • Thanks 1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
