Hi everyone, was hoping someone could help with a problem my r33 gtst has developed. When driving the car above 40mph the water temp needle starts dropping slightly just below the middle level and would stay there untill idle.
When the car is idle the needle is near enough to the middle. When it's cold weather the needle will once again stay below the middle level.
Could this be the thermostat? How do I check it?
Any help is appreciated. Thanks
https://www.sau.com.au/forums/topic/482047-r33-water-temp-low/
in any reasonably modern car, the temperature gauge does not actually show you a straight indication of the coolant temp. They have been setup so they show cold over on the left, "normal" about 80-110o will be in the middle, and then it will suddenly shoot up over say 110.  Any variation you are noticing is not an indication of an actual problem.
If you want to actually monitor the coolant temp you need to either read the ECU data eg via a consult compatible display, or add a separate coolant temp gauge.
While true that the coolant temperature gauge is "dumb" and won't show proper coolant temperatures, if you actually notice it dipping more than parallax error would allow then it's very likely that there is a problem. Get a Consult cable and Nissan Datascan and run some logs to see what the coolant temps actually are in those cases. If it's dropping below 80C first step is to replace the thermostat.
I would probably want to be sure of the issue before actually replacing the thermostat, from what I can tell it's a real pain in the neck to replace.
Edited by joshuaho96
Thanks for the reply. It has always been dead in the middle. Just recently started dropping towards the cold side when I drive fast over 40mph. When at idle it will come back up to almost the middle. I will get a proper water temp gauge and see what that reads.
Thanks for the reply. I will get it checked out before I replace the thermostat
7 hours ago, DaymoR32 said:
if you are talking in mph im assuming you are british or american?
Whats the ambient temperature wherever you are at the moment?
Thanks for the reply. It's winter here the temperature dropped to - 3c couple weeks ago. Now it's been around 5 to 7c. Could that be the reason? Could the air intake be sucking in cold air and cooling the engine? I do have an hks mushroom intake without any sort of box around it.
As others have said replace the HKS trash pods before the foam disintegrates and gets sucked into the turbos, they suck at filtering too which can cause engine wear over time, you'll see more silica content in the oil as a result. That has nothing to do with the coolant temperatures though. If you're driving -3C conditions then it's hard to say, especially if you're running a low temp thermostat and the heater. 5-7C you shouldn't see the engine dropping below thermostat crack temp in normal operating conditions.
Why do soo many people hate on the hks mushroom intake? I understand in hot temps it ain't gonna be good but here in uk we rarely get hot summers and if at most 2 months of summer.
I also hardly drive the car it's a weekend toy have put 1k miles on in 1 year. I get that the mushroom filter can disintegrate but surely if you change it every year it shouldn't?
But Yh il look to see if it drops any further /gets worse, then start looking at replacing thermostat
Look, your reasoning is just stupid on your coolant temp theory. You may or may not have a problem, but as Duncan mentioned earlier you've got no idea what your actual water temp is as your going purely by the gauge on the cluster.
That means jack shit.
"Normally" warmed up at anywhere between 70 - 90c the gauge will point slightly below horizontal - IF your gauge sender is correct. Yours probably isn't. Replace it for a start as they are not expensive.
There is a coolant sensor for the gauge and and one for the ecu. You need to see what your ecu sensor is actually reading.
For example, my 32 gauge cluster indicates a bit high when warm, pointing above the horizontal. I know it's not hot as indicated by the cluster as the engine ECU sensor as read by the Haltech will be reading fine at 80c. FYI stock thermostat opens at 78c.
This is basically the same principle for the oil pressure cluster, it's hardly accurate and you need a REAL oil pressure sensor as there is no ecu oil pressure sensor standard, just a gauge cluster one.
You need real sensors with a real way to be able to measure them.
And yes the HKS filter is garbage as mentioned.
http://mkiv.com/techarticles/filters_test/2/index.htmlbkbk
I also recall reading a report in which poor air filtration caused damage to hot film MAF sensors like those used by the R35 will cause the surface of the film to become pitted and damaged. It's also generally well accepted that the silt taken in by the engine will also get into the oil as elevated silica content. I don't recommend anything other than dry paper filters as a result.
The stock airbox is really not as bad as people claim it to be, people insist on changing what isn't broken though.
Thanks for your input. Any recommendations for aftermarket water temp gauges?
Thanks nice good bit of info to know
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
