32 minutes ago, Mick_o said:
$1570 is a rort. I wouldn't pay that for that heap of shit.
Whoever "some guy" is is a knob lol. I'd go Nistune over Halal all day.
If you want the best its Motec or Emtron really.
29 minutes ago, Dose Pipe Sutututu said:
which donkey told you this?
I’m just getting mixed messages all around. Why exactly is haltech plat pro a heap of shit if it’s very popular and many people can vouch for it and use and why does JEM (reputable tuner of skylines) recommend it?
One random guy at skyline spares told me today(not the owner). Told me he has a 1500hp and 1000hp gtr. He highly advised against getting the nistune and encouraged me to get the plat pro cause he says it’s the best. Said nistune would limit my power to 300kwish
@Dose Pipe Sutututu how much for a 600x300x76 plazmaman intercooler for? Do you know erks he is a welder at plazmaman
Edited by IM-32-FK
Can you stop using the term "the best" as it's completely irrelevant. You need something at a minimum that can tune your ignition and fuel maps properly, which is nearly any ecu really.
The "best" ECU is really just the wide variety of capabilities that the ECU in question can do, which for a long time has been MoTeC. New Haltech Nexus is shaping up to be a game changer, but this is so over the top for what you need we won't go there.
When you start talking flex, minimum requirement for you is going to be a Nistune, Platinum Pro or a Link G4.
If you can stretch, the Haltech Elite will be more than you will ever require.
I have been using the Wolf ecu for the past 6 and a half years without any problems my car is currently tuned at 473hp and it get rid of the air flow meter Australian owned and produced with good backup and lifetime warranty on ecu go to a good tuner and your probs are gone
I’m just a bit confused that’s all. Nistune seems to be the cheapest option right now, with my setup I’m going for, is it more than enough? Either 650 +200 for afm for nistune or $1570 for haltech pro. Also I heard some power fc is L Jetro edition , how can I check if mine is that?
19 minutes ago, BK said:
Power FC L jetro - AFM only, which is the most common version.
Power FC D jetro - MAP sensor only
Oh shit I got mixed up, so the D version is the rare one with ign cut and mafless? Does it allow e85 flex as well?
No flex on any. L or D jetro version also does not have ignition cut either, both fuel cut. The Power FC PRO had the ignition cut and launch control, which was a modified version of the L jetro. I have had all three versions on my blue GTR.
Remember you can't Nistune a 33 ECU either.
Man up and get an Elite 2000 or 2500 👍
  • Like 1
Costs too much money, way out of my budget. I found a nistune for $400 I’ll probably just go with that. It’s just that since I can’t go mafless I’m a bit worried about the length of the turbo intake piping. It’s gonna need to be shorter and I’m gonna have to use a tiny pod filter like I am now(it’s hitting the coolant reservoir). This may sound stupid but can you take the maf sensor off the z32 and weld it into the turbo intake piping so you don’t need to use the maf housing? This way I got more alloy piping and a bigger pod filter
Edited by IM-32-FK
Get a R35 card AFM and weld it post intercooler (cold side).
Means you can run any length intake pipe and pod combination without any issues to air flow reading.
Also means you can run a whoosh valve without the car stalling.
What the hell is a whoosh valve my man?😂 I deleted the bov and the bov piping and put a blanking plate on the j pipe so it’s dose piping sututututu right now on my apexi alloy intake pipe. Also I can’t imagine a 35 afm being cheap, how much is it? But do u know if I can remove the z32 afm sensor, delete the housing and weld it onto the intake piping? Kinda like this(this is a hpxn1 maf sensor after market)
Edited by IM-32-FK
11 minutes ago, Murray_Calavera said:
If your happy to pay $1500 for a platinum pro, you can have mine. I'll even install it and tune it free of charge! (Provided you have a wideband sensor, can't tune without it)
Are u in Sydney?
Right this second, yes. But currently living in outback nsw.
I'm serious though, happy to drive to you, install the platinum pro and tune it for $1,500.
And if your keen, I can explain the entire tuning process. The whole teach a man to fish thing.
Bargain!
I wouldn't even get out of bed to supply, fit & tune any ECU for $1500.
Real question is will it make bangs and flames.
you would do it in bed?
The only real criticism I can think of regarding Nistune is that the ECU inherently expects proper matching between the fuel injector and AFM. If your fuel injectors are massive relative to what your AFM will provide then you will run into problems. You are also limited to the stock CAS signal format for signaling so crank triggers aren't going to work unless someone releases a 180 tooth crank trigger with digital trigger output. It's just a very different way of thinking that most tuners are not used to, everyone in the aftermarket tuning ECUs is used to speed density and alpha-N tuning. Anything that doesn't fit in that box is going to get dumped on to some extent as a result. The ECU is also really only made to do what it does stock in terms of I/O and not much else, although the Feature Pack stuff does add more neat goodies.
  • Like 1
Oh yeah, how long are you in Sydney for? Also have u got the wide band, intake temp sensor, pigtail etc?
and how many days will it all take you reckon?
maybe we can work something out where I can leave my car with you and u can install everything like turbo, walbro, injectors etc. I still need to v band the dump pipe and get pipe made or the turbo elbow part and a turbo intake pipe made
Edited by IM-32-FK
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8th Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
    • Just yesterday the car started to shake a bit when idle. So tomorrow ima test the some wires and packs with the multimeter and see what it is. Hopefully is a pack because thats the easiest thing to buy same day here where I live in the USA.
    • shot myself in the leg and now last night I have shaking when I idle lol
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
