19 minutes ago, khezz said:
You and Paul are a "HORSEPOWERISTS". When I get 1200rwhp I'll wonder why it broke and I don't want to hear shit from either of you @freehorsepower
Yeah but you'll be prepared because you'll know why it broke !
  • Like 1
I had a call from PPG just a few minutes ago as I am in the market for a gearbox my self. I am, funny enough, chasing around 1200awhp. PPG dog box has larger helical gears then the sequential. I did not know that. PPG assured me that dog box will handle my power goal better then sequential. So might be an option to save money and improve reliability. Waiting on a price for helical and straight cut options.
H pattern has wider gears being a 5 speed in the same case. When I was looking to go back to a dog box my quote for fully optioned PPG straight cut H 5 speed dog assembled in case was around $15.5k.
For comparison I ended up with the PAR 5 speed straight cut H pattern dog which come in at around $11 - $12k assembled by Sam at Neat Gearboxes. Main difference in price was the PPG gearset is about $2k more than the PAR and the PPG price included the optioned billet main shaft. I was talked out of billet main shaft on a GTR as they really don't break because the shaft is so short, unlike a rwd case having a much longer main shaft.
As you're going for 1200rwhp I'd only be considering straight cut gears, not helical. If you mentioned your power goals I'm surprised they even suggested the helical dog H pattern gearset as their own power rating is below the straight cut set.
For comparison I ended up with the PAR 5 speed straight cut H pattern dog which come in at around $12k assembled. Main difference in price is the PPG gearset is about $2k more than the PAR and the PPG price included the optioned billet main shaft. I was talked out of billet main shaft on a GTR as they really don't break because the shaft is so short, unlike a rwd case having a much longer main shaft.
As you're going for 1200rwhp I'd only be considering straight cut gears, not helical. If you mentioned your power goals I'm surprised they even suggested the helical dog H pattern gearset.
Ppg say helical will be ok but if I can live with the noise of the straight cut gears, I should go that rout as there is more margin for error (my error).
47 minutes ago, BK said:
I would say back to PPG, show me a 1200rwhp + GTR running a helical 5 speed dog. I don't believe there is one running that kind of power that's not on the straight cut in H pattern.
I am sure you are right. I am definitely going the straight cut rout. Complaining about noise in a car like that is right up there with complaining about fuel economy. I am sure I'll make plenty of errors while learning the car so any room for error is welcome.
Edited by khezz
  • Like 1
I dig straight cut. When you say room for error though, having a H pattern dog you a more likely to damage it if you don't know how to drive it. This is where sequentials come into their own because they are easier to use. When setup correctly they will wear the dogs less than an H dog as you always shift into gear correctly.
Not so with an H pattern. Quoting myself from the Big boss thread-
On 11/04/2021 at 11:13 PM, BK said:
OS giken with their OS88 state that, which is just covering their arse really. PPG early on with their H pattern had over 20000km without a teardown, proving that you can make them live without constant rebuilds. If you get to understand the mechanics of a dog box you'll understand what operational habits wear / damage them and what doesn't. At the end of the day they have to be unloaded to shift out of gear and synchronise the gear speed to select incoming gears without damage.
Sequentials are are great for this with dog boxes when strain gauge ignition cut is implemented for gear changes, as it unloads the gearset just long enough for the shift event to occur correctly. Shifting down gears is especially more tricky again with dog engagement, as it's easier to overspeed or underdpeed the gears on the shift event. Things like throttle blip ECU control, again usually in sequentials help with this gear speed matching to stop gear underspeed on the downshift.
This is why H pattern dog engagement boxes do actually require quite a fair bit of learning to get right, because the rev matching and gear unloading process is all completely manually done by the driver.
  • 7 months later...
Looking at going back to a sequential set up myself for my car, had a PPG sequential in it previously, have done a lot of research and have tried to speak with as many people as I could, messaged a few members on here who run sequential to get their thoughts.
For me it was a hard decision, still tossing up as I have been offered a very good getrag, I want the car to be as ‘street friendly’ as possible so I have ruled straight cut out.
But having owned a sequential, I did fall in love with it, car was unbelievably fun with it, felt horrible going back to a synchro box (stock box). So at this stage, I’m really leaning towards the Holinger.
But for anyone considering sequential I can’t stress enough, take your time, do your research and talk to people who have them before pulling the trigger.
On 10/12/2021 at 11:46 AM, r32-25t said:
Gone up since the last price I got quoted
If people don't believe it, I'd be happy to post the quote up for arguments sake.
Personally, I don't see how PPG's helical gears can be stronger then straight cut dogs, which is why I didn't go with a PPG. Personally, I don't care how loud my gearbox is. I'd rather have a loud, and reliable setup, over a docile, and not so reliable setup.
I have just recently purchased the PPG Billet Sequential, but i definitely did not pay anywhere near that 32.5k AUD. I am happy with what ive got, as i am not chasing 1200+whp. Compared with my friends OS88 and Samsonas, the samsonas is definitely the business no doubt, but i believe it is a lot better than the ageing OS88
  • Like 1
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
