Can't find a thread on this so decided I'll make one to hear opinions. Just want to get some opinions on the different intake manifold options for RB's, particularly if you have actually seen or experienced the ones you're going to mention.
Has anyone used the Otaku Garage ones, NPBoosted etc? Reputable or just look the part?
And yes I'm aware plazmaman is great, just want to see all the options and what's out there, because mostly I see people run either plazmaman or cheap ebay lol but surely there are more?
Also have a number of my own reasons for running an ffp, for anyone who's gonna tell me to stay stock. Aesthetics is certainly one, which is why I'm not actually too fond of plazmaman haha
So leave your opinions and reviews below.
https://www.sau.com.au/forums/topic/482778-intake-manifoldplenum-options/
Otaku/rep/copies notorious for splitting
Any short runner manifold will be a performance hit in the low/mid range, even the plazmaman one.
Used Genuine Greddy and lost all low/mid torque, Quality was good 2007/2008
Currently using Plazmaman Plenum on std runners. Got all my low down torque back and Quality is great 2018
  • Like 1
That's interesting as I haven't heard bad things about otaku intakes yet, but I haven't heard much about them either. And yea def don't want to sacrifice too much low down, I've got an Rb20det after all haha
Does the Nismo plenum make more sense then for people that want to light a lot of money on fire for basically zero benefit? They claim the intake runner length is 73.8mm compared to 48.5mm for the OEM part. Plenum volume is 4.1L vs OEM 3.4L. Supposedly cylinder 5/6 have a different runner geometry as well to try and get it to have more even air/fuel distribution.
On 9/1/2021 at 4:44 AM, joshuaho96 said:
Yeah, this is an RB26. Probably should've mentioned that part.
In that context, the Nismo plenum, if it offers the benefits that they claim, would be a good thing. The larger plenum volume will certainly help on big power cars. The improvements to the runner geometry might help. The length increase would be unnoticeable (except inasmuch as it might contribute to the large volume).
Thanks for the comments so far.
Anyone else have experience with different intakes? Seems to be a case of either buy plazmaman/greddy or some ebay junk (or fancy name ebay junk with their own website) lol
It's for an Rb20det btw
Have a look at IMR in NZ.  He’s a one man show that makes some pretty awesome intakes.  I’ve got one for my car that will be DBW. It’s very well made and looks awesome  I’ll probably powdercoat it as well ven though the raw aluminium looks bloody good.
Mine-
You’d have to hit him up for a price for an RB20 manifold as it will be obviously different to an RB26.
I would keep the stock RB20DET plenum and run Plazmaman swept back piping.
Save that money and put it towards a sex spec modern turbo with a divided housing, twin scroll manifold, twin gates. That RB20 needs all the help it can get And throwing a plenum on is going backwards.
  • Like 1
Not keeping stock, for a few reasons like I said. I do intend to keep the runners as long as I can to not lose so much low down torque. Aside from short runners causing the curve to be higher in the rev range, therefore sacrificing low down, a forward facing is not going backwards.
It's also getting a 6boost manifold and a Garrett turbo lol so those are in the plans
Mine-
Thanks for the input I'll have to look into it, but def need runners to be a lot longer than that lol
Just remeber you don't have VCT and you have a 2.0L motor so the best option here if you want to go FFP is the Plazmaman plenum that utilises the stock runners.
Remember to go a divded rear housing on the turbo and twin scroll manifold. You'll need all the help you can get.
Yeah plazmaman def seems to be the go, I was hoping to see if they had a good competitor for performance that just looked better hahah. But options are just a bit more limited on an Rb20det, without sacrificing what little it has low down lol
These are the key points. Any sacrifice of what the RB20 has to offer before the boost threshold only hurts driveability. You can make an RB20 make lots of power, but when you do you get nothing, nothing, nothing, wheelspin.
I'm not disagreeing lol it's a street car so I want drivability, hence my search for a good intake that doesn't have tiny runners. There's always gonna be *some* sacrifice. But I'm not chasing massive power so it should be still good to drive, for huge power I'd look for an rb25det.
Bad things are literally all you hear about the Otaku Garage intakes.
  • Like 1
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
