hello! i am looking into upgrading the cams on my rb26 in the future, and wanted to start to understand what goes into this. i did a forum search and nothing obvious came up, so forgive me if this is already discussed somewhere.
currently the engine is stock, save for (pertinent to this discussion):
  • adjustable cam pulleys
  • beefed up timing belt
  • haltec ecu, not yet installed yet
  • oil baffle plates
i am will be converting to a single turbo set up, and that turbo's peak output is reached at somewhere between 5k and 5.5k rpm. this would be for street use.
from what i understand, i should be looking at cams degreed at 272°. does that sound like it makes sense?
there are step 1 and step 2 variants of these cams. i am not sure what the difference is in the to variants, so if anyone can chime in on this it would be great.
i am assuming i would need to upgrade my valve springs as well. other than a tune, what would go into a camshaft upgrade? if i want to go with a v-cam upgrade much later, how does that affect i am doing now?
i understand that it's totally possible that i completely missed something major here, but that's why i am posting this: i am here to learn.
cheers!
https://www.sau.com.au/forums/topic/483073-camshafts-upgrades-and-options/
  • oil baffle plates
cheers!
VCAM requires a special intake cam in order to be able to actuate the cam phaser. So you are limited in your selection there, usually you want to match your intake and exhaust cams to some extent. Turbo engines are not the same as naturally aspirated engines. Once the engine is on boost it matters less if your VE is tailing off when you can just increase the boost solenoid duty cycle to compensate. Most turbos also have significant backpressure which can favor less valve overlap than you'd expect at high RPM compared to an NA engine as the pulse tuning effect of exhaust runner length is competing with the exhaust backpressure causing internal EGR. It's likely that these effects are why the factory exhaust cam is said to be lower duration and lower lift than the intake cam.
I would love for there to be public data comparing the effect of staggering cams in either direction (more duration on intake vs exhaust and vice versa) for the RB26. As far as I can tell nobody has done it.
On 12/7/2021 at 5:37 PM, GTSBoy said:
Using terms like step 1 and step 2 makes me think that you are looking at shitty old Jap cams, not Kelfords.
Just go to Kelfords RB26 page and pick the cam that sounds like it suits your needs.
they replaced 'step x' with '-x'. brilliant. other than that, is there a reason why you think these are superior in any way to 'shitty jap cams'? it would be helpful if you gave some kind of reasoning behind your recommendation, or at least tried to answer the actual question that was asked.
On 12/7/2021 at 5:58 PM, r32-25t said:
Also unless you clearance the head you are limited on how much lift you can have
i assume the lift dictates if i will need to modify the cylinder head, correct? at what point does the head need to be modified? if the lift goes above 9mm?
Edited by itsforandres
There's a lot more to how well a cam profile makes air flow into an engine than just the number of degrees and the lift. The lift curve around the seat in particular, the width of the peak of the lobe, the maximum accelerations imposed on the valve on the ramps.....all of these, and some more, are important. The shitty Jap cams do not go anywhere near doing the best on any of these. Kelfords have put some proper thought into all the cams they do for all engines. Cam specialist vs. Jap brand name selling specialists.
  • Like 3
Reminded me of this
  • Like 1
  • Haha 2
@GTSTBOYthank you! this makes much more sense. from looking at the shop manual for the cylinder head, it seems you can access the valve lifter, valve collet, valve spring retainer, valve spring, valve spring seat, valve oil seal, valve guide, valve seat, and the valve without removing the actual head. am i understanding that correctly?
is it recommended to replace the valve lifters, or just service them?
On 12/8/2021 at 2:25 PM, r32-25t said:
Usually 9.15 is the limit before needing to clearance the head
@r32-25t thanks! much appreciated.
does anyone have any dyno results to post of Kelford etc cams vs HKS/Tomei cams on like for like setups, to show the specific gains between the 2? I went with Tomei poncams but interested to see the benefit of others compared to these.
  • Like 2
I should be able to provide those details soon, however won't be a clean comparison 🤓
Same-ish engine, nearly like for like (new motor, same displacement, same turbo setup, same valve springs, just different intake manifold, different cams)
Not exactly like for like but good enough.
Tomei 260/260 9.15mm vs. Kelfords 264/272 9.60mm
  • Like 2
There are other benefits to going with a dedicated cam manufacturer. It's sad that we're reduced to just Kelfords, now that the Aussie makers are gone. But while we still have them in our backyard, we should support them.
The support you get from people like Kelfords, when deciding what to use and for trying to solve problems is priceless. The extra stuff and effort available in the areas of springs and retainers, etc etc, knowing that they will only provide gear that matches their stuff.....you work out what that is worth to you.
  • Like 2
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
