On 19/04/2022 at 7:53 PM, BK said:
Genuinely trying to make you understand how it works.
Have a look at results for the Precision 5558 or 5858 on an RB20 to see if they are to your liking - they are out there
Thanks will do, examples like this is what I'm looking for. For the likes of an Rb20det I'm not sure how well something like a 3071r (just for size example) would spool, or perhaps smaller. Be interesting to see if anyone has made any decent response improvements with say twin scroll manifold and better cams
Too small for the rev range you're talking about. Do the maths on the torque that you'd expect/want the engine to be making, multiplied by the revs (north of 9k) and that's your power number. That gives you your turbo flow requirements.
There's no point in revving it high if it's not making torque up there. If you're not making >350Nm.....
I found something that might be of interest to you, its not an RB20, but I think it might be of interest because its a similar capacity turbo car that revs to about 10,000 RPM. Power comes on about 6,000 RPM. Seems to be around what your looking for.
I hope you've got the budget though, the turbo on its own is about $6,000.
Appreciate the feedback although I think you've missed what I wrote before. 8000 to 9000 is where I said I'd like to be if feasible (not trying to get to 10k because that's a lot of extra work), but the hpa video is interesting since it made power from 6k to 10k, then perhaps it seems possible to make power from 5k to say 8500 or even 8250
Fair point. Roughly what rpm would you say a turbo this size would Max out at?
8-9k is achievable on a basic RB anyways. But if your turbo is falling off at 7, then there's no point in revving it any higher. Mines fully built, and I only rev mine to 9.
So....the genuine GT3071 is good for something like 500 engine HP, maybe a smidge less, and on a small engine like an RB20, almost certainly less rather than more. At 9000 rpm your engine needs to be making 400Nm (!) of torque in order to make that much power. If you want peak power at 9500, then you only need to make 375Nm.
So, realistically, despite what the other guys are saying (for reasons I will get into below**) there is actually no "what rpm would you say a turbo this size would Max out at?".....so long as the engine configuration is flexible. By "engine configuration" I mean the cams, porting, compression and so on that determine where it wants to make peak torque and how high it will be able to rev.
** If you're talking about a mostly stock engine, like the other guys are mostly basing their statements on, then yes, you need to match a turbo's capacity to what the engine can use at the stock rev range, or only slightly more. It's all the same calculation - how much boost and mass flow rate of air from the compressor map against what torque the engine will need to make at your anticipated peak power revs, and whether it is then possible to make that torque from that much boost. If the engine can't make that much torque, then the turbo is not a good match. If the engine can make that much torque at that boost, but the turbo can't flow enough (or is actually too large and perhaps running inefficiantly) then the turbo is also not a good match. Doing this from first principles is quite difficult, which is why most people just work from anecdotal evidence, ie "this engine did X with turbo Y", and then extrapolate from there.
On 4/18/2022 at 9:06 PM, Chopstick Tuner said:
Sure I'd love to rev to 9k, but if my Rb20 lags like hell until 5 or 6k then it's probably pointless lol
going round in circles a bit.
what do you really want from the car? Why are revs the main focus at the moment?
On 20/04/2022 at 11:46 AM, admS15 said:
Convert to 13B BP or PP. Problem solved, endless revs and the noise, that delightful noise..
Can confirm, a mate has a 500whp bridgeport 13B R32 GTS-t and it's hilarious fun :)
Edited by Lithium
  • Like 1
On 20/04/2022 at 12:25 PM, GTSBoy said:
This is very interesting to me. In that....."how can I make my car both better and worse at the same time?" kinda way.
Haha, well the old engine was an RB20 so realistically there isn't much that is worse going to a 13B aside from reliability.
On 20/04/2022 at 12:44 PM, GTSBoy said:
Yes, that is definitely the "worse" thing I was talking about.
To be fair that hasn't actually been an issue, it's been running for near a decade (granted, no daily haha) and I went for a hoon in a few months ago so I assume it's not THAT bad.  The engine is likely to get pulled to put in a 20B for awesome as opposed to necessity :)
On 20/04/2022 at 2:00 PM, Komdotkom said:
Why no quad rotor? Twice as reliable.
Perhaps.
But epic sound!
20B is a LOT cheaper to build and easier to install, and in some ways the sound may make people second guess what's in it as well.  Hopefully with a decent matched turbo it should be peppy enough :)
They make great power too, a mate has a 20B S4 RX-7, but even used motors are fetching huge dollars now.
But they don't sound like a 4 rotor. I've always wanted to this to my 240z but I've already got enough projects.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
