On 7/5/2022 at 4:43 AM, joshuaho96 said:
 I plan on replicating the stock ECU map as much as possible on a Haltech Elite ECU but it’s blocked by registration issues.
And this is why American will consume more RB engines then the rest of the world
Tuning comes later, I just want to make sure that I change as few variables as possible. I'm not particularly well-equipped so I can't make a whole base map from scratch and make it flawless.
On 07/05/2022 at 7:31 AM, joshuaho96 said:
Something I've been thinking about for a while is why with ITBs everyone is still using pure TPS in certain cases instead of throttle mass flow or something like that. It seems insane to me to tune based on a variable that doesn't actually represent engine load
You would use run both Alpha-N and MAP for load, something the Haltech does very well if you add in another dimension to the fuel / ignition tables.
Does that translate really to a mass flow value though? I thought it was basically using TPS as the primary load, with the MAP primarily functioning as correction once you get on boost. TMF still requires blending at the top end, but as you approach WOT alpha-N is a pretty decent strategy anyways.
On 5/6/2022 at 5:24 PM, GTSBoy said:
That hasn't been true since the 90s. If anyone is still doing it it is because they are daft.
In my head I was thinking of the popular MAP + TPS blending. As far as I can tell there is still significant portions of the engine map where the load is almost entirely TPS + barometric correction from the MAP and not much else. In the Haltech base maps fuel load is pure TPS.
Because it's meant for you to start it, check everything and baby it to the tuner.
Not side step 3rd gear and do 8k RPM launch.
  • Haha 3
On 5/7/2022 at 12:29 AM, Fizurg said:
So if I changed the turbos and put in a Nistune. Would the base map be safe to drive on?
The base map is identical to the stock ECU. Nistune just allows you to edit the stock ECU tables in real time and has live tracing/logging functions too.
  • Like 2
Define ‘drive on’?
Really, change of snails = a tune. The only driving one should do is to the tuner… using the best boost controller there is… your right foot!
  • Like 1
Ok I'll weigh in here since I've done it.  When I blew a stock turbo on my 33 18 years ago I changed to the HKS GT-SS, which is almost the direct equivalent of -9 (HKS has bees dick bigger compressor wheel, exhaust side identical)
I drove it 1500km to Adelaide on the factory fuel pump, injectors and ECU at the speed limit of 110 - 130kph.
When I got there ECU was changed, fuel pump changed, twin Z32 AFM installed, 700cc injectors installed and then was on the dyno a tuned to 330kw on 98ron unleaded at about 1.3bar.
Moral of the story is - yes you can put these turbos on and drive it ok, as in no boost. Change turbos, keep it low load on vacuum and drive to wherever you want and get it tuned and it will be fine.
  • Like 2
  • Thanks 1
Personally I'm holding out for the base map that uses a neural network for cylinder air charge estimation that takes all the work out of it.
OK, so what turbos could i run? can i have my factory turbos rebuilt with steel internals and they will bolt on and run fine? if not having a tune was an option what are the best turbos to put on? i know this doesn't fit well with performance but realistically the car wont be drivable for years if what i do will be too expensive and it would just be nice to be able to drive it.
yes, standard turbos rebuilt with steel wheels in the same size and same/similar boost will be the cheapest way to get going again....no tune issues that way. Plus, rebuild is cheaper than all new turbs as no other fittings/exhaust/etc changes are required
cool as. this option I guess makes the most sense. it gets my car back on the road and although its not ideal as far as performance goes, there are worse things than having a factory original R32 GTR. its also by far the easiest sell to the Mrs which makes life easier.
Cheers for all the help ive been given so far. ive been a member of many car forums over the years and they have always been by far the best source of information ive ever found. this one in particular is active, knowledgeable and friendly, so very much appreciated by me. im sure i will have more stupid questions going forward.
I would just make sure the parts are good. Hard part is making sure the turbos are rebuilt properly as well, those things spin at some ridiculous RPM so there is very little tolerance for any mistakes. I would probably ask Hypergear to see if they could do it. Likely not the cheapest option but I would value someone experienced that can do the job right over having to pull the turbos multiple times. I'd be suspect of most ebay rebuild kits, mostly because it's so hard to know the exact provenance of those parts.
There are some people who know what they're talking about, I'm just some random kid that doesn't really know what they're doing. So don't worry too much about it, you're in good company.
yeah that is my next concern. im based in NZ and im not really sure who to use. there are plenty of companies that rebuild turbos but how to know which one will be good could be tough
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
