11 minutes ago, Dose Pipe Sutututu said:
Just checked again, and yes both APP1 and APP2 are pretty much in sync
Interesting! Thanks for posting this.
makes me wonder how the pedal was able to calibrate..
maybe i need to try a different pedal?
in other news I have decided on my buttons for the keypad:
13 minutes ago, Dose Pipe Sutututu said:
try borrow a pedal off another car :)
Not setting up rolling anti-lag?
I need to setup cruise control too but I've run out of inputs and can't feed the brake pedal in haha
We’ll see about the anti-lag… it’s a stock motor (for now)..
yeah, it’s so easy to chew up all the AVI’s and SPI’s! I needed the PDM for the additional inputs.
What pedal do you use? From what I have read is different pedals can do things slightly differently…
https://my.prostreetonline.com/2014/09/24/test-vq35-accelerator-pedal/
this site is saying the 350z pedal APP outputs should be different, which aligns with what I’m seeing…
Also, I’m wondering if this may be a source of my problem:
https://forums.haltech.com/viewtopic.php?f=30&t=35278&p=74212&hilit=350z+pedal#p74212
apparently the injector return current powers the dbw circuit. Now, as I have removed the fusebox and gone PDM (the injectors and injector return are now fed from an 8A HCO output), which I don’t think I have set this output up..
Their problem also seems Identical to mine. I will have a play in the morning and report back.
I'm using a V35 Skyline pedal, same as the 350Z one but without the alloy pad (I did have a 350Z one but sold it as I wanted a rubber pedal to match the brakes/clutch).
Doesn't say what car/setup so hard to say.
Generally Haltech support is good at getting back to you, probably still off this week. Hopefully next week you'll get a response
  • Like 1
Problem all sorted. Thanks for your help @Dose Pipe Sutututu.
I had the “disable injector power when engine stopped” option on, which was stopping a +12v supply to pin A26. Turned the option off and all calibrates fine!
also, the FPG shroud came:
just waiting on some new Deutsch connectors to connect it up.
  • Like 2
Just now, Dose Pipe Sutututu said:
FPG shroud looks pretty decent!
How are the air flaps held in place?
They have 3x rubber tabs on each one that are pulled through pre-drilled holes. They are nice and tight. Quality is A+.
Nice!
might be an option if the current fan clutch dies :D
I really hope someone slides into my DMs and wants to buy my car, I'll then stop donating money to the Nissan car gods.
Nice!
They are also releasing their aircon kit for the 33 in the next week or two… I have been looking into a new condenser for mine and can’t get anything under $1k. I’d rather spend more and overhaul the entire system..
haha. honestly, I’ve had an F80 M3 and as fun as they are, they are so intimidating maintenance wise. I was always scared I heard a noise etc. and there was no way I’d try work on that car.. BMW gods are much worse on the wallet..
23 minutes ago, Dose Pipe Sutututu said:
lol... it's a never ending money pit isn't it? LOL.
Your car will be the best built R33 GTS-t I reckon, modernising a 90s JDM to match your previous F80 M3 that was stock lol.
Haha, mine is nowhere near the calibre of some of the builds on here..
That’s the thing, I’m kinda expecting breakages in the 33 and that doesn’t phase me being that it’s now 27 years old. And when it does break, then I’ll even try fix it myself..
I’m looking at upgrading my ‘work’ car from a kodiaq to an RS4/6 later this year, then I can have the best of both worlds..
  • Like 1
So no major progress, just sorting minor technical issues..
Haltech Temp Sensor Wiring - it appears that not all AVI’s are created equal… I’m a real beginner at this stuff, but when I mapped out my wiring plan, I used the haltech wiring diagram as a base. Now what wasn’t overly clear (to me anyway) is that temp sensors need an AVI with a pull-up resistor enabled for them to function properly. After several hours of troubleshooting and searching the haltech forum I figured out why my oil temp sensor kept reading 120deg… now I just need to re-pin my AVI’s around for all the sensors to work 100%.
IC7 Dash - there is just a couple of minor things that is holding it back from being 100% perfect… one of the main ones is the text boxes extend over the ‘bezel’ areas for some of the display boxes. You can see what I mean for my ODO below:
the other is that the dash does not act as an I/O extender, so the dash AVI’s are not available to the ECU. However, talking with Haltech, both of these issues will be resolved in an upcoming update to the dash. So @Dose Pipe Sutututu looks like this might be best for you, as you’ll gain a couple of AVI’s to get your cruise control going…
  • Like 1
Thanks, that is good information. It's pretty frustrating that Haltech aren't more public with their plans as this has been an obvious frustration since IC7 was launched. There was never an obvious reason that the dash could receive but not send on the CAN
In my case for example, I didn't have any ECU inputs left for GPS speed so I had to wire it into the dash, but GPS speed is critical to help implement the 200klm (or now maybe 140klm/h) limit for rallying. I was starting to research which other ECU vendor I should move to as a result, Haltech could have saved us both some trouble by saying this was on the roadmap
  • Like 2
So I thought I was pretty much done with the mechanicals, so decided to add add de-mineralised water to the cooling system. However, It wasn’t long before I heard a steady drip of water on the ground… bugger. A quick investigation showed it was one of the heater hose junctions at the back of the block. I contemplated trying to fix in place but I decided to just bite the bullet and pull the intake manifold off. Sure enough, I hadn’t tightened one of the clamps for the turbo water feed. Tightened that clamp and checked all others and then got the manifold back on.
while I had the manifold off, I decided to do a bit better harness routing to tidy it up a bit..
The fuel system has been checked for leaks (there were none) and the car is now sitting with water and fresh Penrith 10tenths 10w40 oil. Once I set my base fuel pressure, it should be ready to crank for oil pressure and possible first start tomorrow.. somewhat terrified.
  • Like 3
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
