NZ R33 Long Term Build
11 minutes ago, Dose Pipe Sutututu said:
Just checked again, and yes both APP1 and APP2 are pretty much in sync
Interesting! Thanks for posting this.
makes me wonder how the pedal was able to calibrate..
maybe i need to try a different pedal?
in other news I have decided on my buttons for the keypad:
13 minutes ago, Dose Pipe Sutututu said:
try borrow a pedal off another car :)
Not setting up rolling anti-lag?
I need to setup cruise control too but I've run out of inputs and can't feed the brake pedal in haha
We’ll see about the anti-lag… it’s a stock motor (for now)..
yeah, it’s so easy to chew up all the AVI’s and SPI’s! I needed the PDM for the additional inputs.
What pedal do you use? From what I have read is different pedals can do things slightly differently…
https://my.prostreetonline.com/2014/09/24/test-vq35-accelerator-pedal/
this site is saying the 350z pedal APP outputs should be different, which aligns with what I’m seeing…
Also, I’m wondering if this may be a source of my problem:
https://forums.haltech.com/viewtopic.php?f=30&t=35278&p=74212&hilit=350z+pedal#p74212
apparently the injector return current powers the dbw circuit. Now, as I have removed the fusebox and gone PDM (the injectors and injector return are now fed from an 8A HCO output), which I don’t think I have set this output up..
Their problem also seems Identical to mine. I will have a play in the morning and report back.
I'm using a V35 Skyline pedal, same as the 350Z one but without the alloy pad (I did have a 350Z one but sold it as I wanted a rubber pedal to match the brakes/clutch).
Doesn't say what car/setup so hard to say.
Generally Haltech support is good at getting back to you, probably still off this week. Hopefully next week you'll get a response
  • Like 1
Problem all sorted. Thanks for your help @Dose Pipe Sutututu.
I had the “disable injector power when engine stopped” option on, which was stopping a +12v supply to pin A26. Turned the option off and all calibrates fine!
also, the FPG shroud came:
just waiting on some new Deutsch connectors to connect it up.
  • Like 2
Just now, Dose Pipe Sutututu said:
FPG shroud looks pretty decent!
How are the air flaps held in place?
They have 3x rubber tabs on each one that are pulled through pre-drilled holes. They are nice and tight. Quality is A+.
Nice!
might be an option if the current fan clutch dies :D
I really hope someone slides into my DMs and wants to buy my car, I'll then stop donating money to the Nissan car gods.
They are also releasing their aircon kit for the 33 in the next week or two… I have been looking into a new condenser for mine and can’t get anything under $1k. I’d rather spend more and overhaul the entire system..
haha. honestly, I’ve had an F80 M3 and as fun as they are, they are so intimidating maintenance wise. I was always scared I heard a noise etc. and there was no way I’d try work on that car.. BMW gods are much worse on the wallet..
23 minutes ago, Dose Pipe Sutututu said:
lol... it's a never ending money pit isn't it? LOL.
Your car will be the best built R33 GTS-t I reckon, modernising a 90s JDM to match your previous F80 M3 that was stock lol.
Haha, mine is nowhere near the calibre of some of the builds on here..
That’s the thing, I’m kinda expecting breakages in the 33 and that doesn’t phase me being that it’s now 27 years old. And when it does break, then I’ll even try fix it myself..
I’m looking at upgrading my ‘work’ car from a kodiaq to an RS4/6 later this year, then I can have the best of both worlds..
  • Like 1
Apart from commodores and falcons the entire Australian used car market is ridiculous compared to the rest of the world even before Covid tax
usa 996 turbo 20k Australia 100k pre Covid
  • Sad 1
So no major progress, just sorting minor technical issues..
Haltech Temp Sensor Wiring - it appears that not all AVI’s are created equal… I’m a real beginner at this stuff, but when I mapped out my wiring plan, I used the haltech wiring diagram as a base. Now what wasn’t overly clear (to me anyway) is that temp sensors need an AVI with a pull-up resistor enabled for them to function properly. After several hours of troubleshooting and searching the haltech forum I figured out why my oil temp sensor kept reading 120deg… now I just need to re-pin my AVI’s around for all the sensors to work 100%.
IC7 Dash - there is just a couple of minor things that is holding it back from being 100% perfect… one of the main ones is the text boxes extend over the ‘bezel’ areas for some of the display boxes. You can see what I mean for my ODO below:
the other is that the dash does not act as an I/O extender, so the dash AVI’s are not available to the ECU. However, talking with Haltech, both of these issues will be resolved in an upcoming update to the dash. So @Dose Pipe Sutututu looks like this might be best for you, as you’ll gain a couple of AVI’s to get your cruise control going…
  • Like 1
Thanks, that is good information. It's pretty frustrating that Haltech aren't more public with their plans as this has been an obvious frustration since IC7 was launched. There was never an obvious reason that the dash could receive but not send on the CAN
In my case for example, I didn't have any ECU inputs left for GPS speed so I had to wire it into the dash, but GPS speed is critical to help implement the 200klm (or now maybe 140klm/h) limit for rallying. I was starting to research which other ECU vendor I should move to as a result, Haltech could have saved us both some trouble by saying this was on the roadmap
  • Like 2
So I thought I was pretty much done with the mechanicals, so decided to add add de-mineralised water to the cooling system. However, It wasn’t long before I heard a steady drip of water on the ground… bugger. A quick investigation showed it was one of the heater hose junctions at the back of the block. I contemplated trying to fix in place but I decided to just bite the bullet and pull the intake manifold off. Sure enough, I hadn’t tightened one of the clamps for the turbo water feed. Tightened that clamp and checked all others and then got the manifold back on.
while I had the manifold off, I decided to do a bit better harness routing to tidy it up a bit..
The fuel system has been checked for leaks (there were none) and the car is now sitting with water and fresh Penrith 10tenths 10w40 oil. Once I set my base fuel pressure, it should be ready to crank for oil pressure and possible first start tomorrow.. somewhat terrified.
  • Like 3
 Share
    • Slimline sub on the rear parcel shelf is doable. Pioneer TS-WX140DA is only 70mm high.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
    • Easiest way to know is to break out the multimeter and measure it when cold, then measure all the resistances again once it gets hot enough to misfire. Both the original ignitor and the J Replace version. Factory service manual will have the spec for the terminal measurements.
    • Yes that sounds right. Cars currently in the shop for the engine work. Will need to remeasure .. but yes I think I must be targeting 45cm from fender.
