5 hours ago, joshuaho96 said:
I have zero issues with pad noise running MX72 Plus but YMMV. I'm using the stock Brembos so not 100% identical to your Sumitomo setup.
Are the brembos better than the sumitomos?
Well, yeah. They're bigger, for one thing, so they soak up more heat from stops before calling it quits. They are also stiffer calipers. The Sumitomos aren't terrible, but they are definitely not as stiff as the Brembo calipers.
Update guys: Brakes aren't squeeking as bad during normal driving. They only squeek a little bit now after i mash on the brake really hard and then they will start squeeking slightly when coming to a complete stop. Still a mystery on why that is, but thanks everyone for the help.
Sounds like you didn't install the missing brake shims/hardware.
  • 3 weeks later...
I dont understand how shims will cause that... the squeek is coming back now, but it comes back in really random times. Sometimes when i go on the brakes hard and it gets hot, then it will start to squeel. Sometimes i'll drive normally and it will not make a noise. And sometimes ill drive normally and it will STILL Squeel. This is driving me nuts.
Yeah ok, so have a think about it. What is sound? A vibration that propagates as an acoustic wave?
When the pad and disc make contact, there is vibration. That vibration causes your lovely high pitched noise.
The shims prevent the transmission of vibration.
No vibration, no noise.
Now lets keep thinking about the situation.
You are an OEM. You are trying to make a profit. Why would you manufacture all of these unnecessary brake shim hardware if it does nothing? Is that money well spent?
Look at all of the stock cars around you. They are dead quiet. They have brake shims/hardware.
Your skyline came from the factory with quiet brakes. It also came with brake shims/hardware installed.
If you cannot install the brake shims/hardware, clean off all of the built up brake dust. If you still can't install it, get your hands on a workshop manual, instructions, watch youtube videos or just take the car to a mechanic who can do it for you. It's a 5 second job so should be very cheap to do.
  • Like 1
Shims are changing the Q factor of the resonant peaks in the brake system. Sometimes you might not have the right conditions to trigger those resonant peaks. If you can't fit the shims in the brake pads you need to push the pistons back into the caliper.
  • Like 1
Just remove any shim or pin you like if you don't think it makes a difference. Ignore what Nissan designed. 🙄
  • 1 year later...
3 hours ago, soviet_merlin said:
Is the girlfriend still your girlfriend and does she ride in the car now? :)
It always makes me laugh when I hear things like this, when I was a young bloke I bought a old Mk1 Escort, one of my mates said "how do you expect to have a girlfriend in a old car like this", my reply was "if she doesn't like the car she can walk, and if she is more interested in the car I drive than me she can fark off"
This is how you can tell if you have a good woman, they care not about things like the cars you drive or what it sounds like
Pandering to crazy obsessed women who care more about how they look in a car than the person driving it is something that I've always kept away from
Not saying my Mrs isn't crazy at times, but it's typically me being a idiot that incites the crazy 🤪
  • Like 1
Funny you ask, because its been about a year since i made this post. She is no longer my gf now lol. I have a new one though that didn't mind the squeeling.
  • Like 2
  • Haha 3
On 30/03/2023 at 5:46 PM, admS15 said:
You've had some decent suggestions above now, I'm just going to suggest the obvious.
Change girlfriend, problem solved. Other random unpredictable problems may present themselves. Your experience may vary...
QFT
Seems I provided sage advice. Glad your problem/s are sorted.
  • Haha 5
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
