1 hour ago, soviet_merlin said:
Is there any downside to running bigger brakes when done right? Or is it that people cut corners when it's just for looks and it compromises on a major safety component?
Genuine question as I'm not sure where the hate comes from. Big brakes certainly look amazing.
I think it's more a practicality issue. Done wrong it can definitely be problematic, I see a lot of BBKs that are clearly track-only because they want you to remove/cut away most of the dust shield, have no dust boots on the pistons/generally a full race kind of caliper, require you to grind away significantly at what is arguably a fairly weak suspension knuckle as-is, etc. Pad knockback and wheel bearing issues on track are not unusual to hear about with these cars. Kind of questionable to spend all that money and have it be worse on the street than when you started if it's not a dedicated track toy.
  • Thanks 1
imho, aftermarket brakes to me dictate that the car has alot of power(Not all the time). I used to get heaps of guys who look twice at my brake setup at the lights, and then ask what sort of power im running.
OP - Check out Brakes Direct. I run their full kit on my car and the brakes are fkn amazing.. plus, I get no squeal at all.
Hi. Thanks for the informative post. I don't want to end up with any of the issues you mentioned and would like to avoid cutting etc. That is why I wanted to get peoples opinions who have made upgrades.
  • Like 1
Well, you cannot avoid cutting or removing the dust shields if you're going to go as large as you're talking about.
And you should not even ever just once consider grinding anything off of the upright or any other part of the front suspension/steering, even for a track car. Doing it on a road car should be punishable by death (and it could happen).
AVOID BRAKES DIRECT
Have stuffed around so many mates in the past 18months and hearing more stories of bad customer service.
  • Like 1
1 hour ago, robbo_rb180 said:
AVOID BRAKES DIRECT
I WAS one of the horror stories. I had fitment issues for the front adapters. Rear was ok, just needed the dust shield to be trimmed as needed. I exchanged lengthy emails and even spoke to George and Greg over the phone. They paid for some of the work required to make my adapters fit. I also stuck bigger brake lines in the back as I'm a picky SOB, but once the brakes were fitted it worked like a charm. Didnt get time to push the brakes.. Only did a semi track day in the rain but had no issues pulling up from around 200.
Wow ! It seems everything new is old ! I remember seeing on a early Holden Commadore that was running in the ( I think ) Repco / Redex rally with a set of front dual callipers !
Then I threw a couple of rocks at the Tyrannosaurus rex that was looking funny at me and hid in the back of my cave until it wandered off !
Edited by PLYNX
  • Haha 2
Just get GT-R Brembos all round, convert the rears to drum hand brake too.
A true car enthusiast will appreciate the OEM+ approach, spend the left over money on a Nismo GT-Pro LSD. Enjoy life, then sell the car, profit and buy a M2 Comp.
  • Like 2
25 minutes ago, Murray_Calavera said:
Genuine or reproduction?
Looks like used genuine is still going for 2k+
I got my genuine Brembo stamped 350z track edition calipers for 265$ a pop off Amazon. Both calipers, StopTech disks and a set of Hawk HPS pads came in around 1000$. I have heard though that when ordering from Cardone it's a mix of remanufactured Brembo's and new clones.
Cardone 19-3858 Remanufactured Import Friction Ready (Unloaded) Brake Caliper, Tools & Equipment - Amazon Canada
13 minutes ago, GTSBoy said:
I highlight two words that have a tenuous and troubled relationship with each other.
They're from Cardone, a very large reputable parts manufacturer/remanufacturer in the US/Canada. I have zero concerns.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
