I have a 500hp r34 gtr and I guess its time to upgrade the oil pump gears to something stronger that can handle rev limiter and shock.
I've been looking for billet gears and came over the plazmaman gears for about $380, but then I saw Reimax had some Chromoly steel gears for about $250 parts number: 15110-AAR11-81.  How is the strenght on these? Anyone heard about these shattering? Is chromoly steel as strong as billet?
I have the oem 05u oil pump so the 81mm should fit?
https://www.sau.com.au/forums/topic/485251-what-oil-pump-gears/
I've done the whole gear thing,the problem with gears is that your slapping it into an old housing that's worn and/or out of spec and it causes more issues than it solves
Sure, buy a new OEM oil pump and slap in gears (I also did that 2nd time round), but why? You're already 3/4 of the way to a new Nitto pump (which I did with my 2nd built motor).
TL;DR buy a Nitto pump.
  • Like 1
Doesn't a nitto pump send you down a new rabbit hole ?
The one were you need bigger sump to stop it emptying.
Head restrictor to stop head filling up
Head drain when it does
then a plumb back to sump  catch can for when none of the above works ?
Not being cheeky, serious question as I am putting on a big sumo soon and have a billet gear set but also desire a bit more oil pressure for my vcam. Was thinking gears + a shim to bump pressure.
All true, I have those mods with nitto pump on the race car. But I think the key difference is use; on the street there is no condition where you are reving at 4-8,000 non stop for 20+minutes.  Yes, a couple of seconds up to a speed limit (or well beyond) might start to empty the sump, but you are going to get off it and have it return to idle pretty quick.  I expect nitto pumps are only a problem without those mods for track use
I thought that went without saying.
Kinda like saying buying a bigger turbo sets you down a rabbit hole of buying bigger injectors, fuel pump, ECU upgrade etc.
I would have thought that anyone spending big on an oil pump would also have sorted the rest of the oil control system.
Ok, so let me clarify.. This is a street car that does about 2000km a year. I know a complete billet oil pump is stronger and better but I just cant justify going down the rabit hole (atleast not right now) I have a link ecu that tells me I lose preassure at one pull, because the sump runs dry. I now have about 6,2 liters of oil in oem pan and that fixed the problem. Putting a nitto pump or something will surely drain the sump quicker and ill need a bigger sump and so it begins... I just dont want my oem gears to fail. Surely some billet/chromoly gears will last longer if I center the gears correctly? I also found the reimax gears with a billet backing plate for not too much more $. Is this plate worth getting along with the gears?
Is the engine still in your car and it's currently running without issue?
If everything is currently fine, why not just tune the car to protect the oem pump and drive the car with mechanical sympathy. You could setup a really soft progressive rev limiter, no 2 step/anti lag, stay off the limiter as soon as it starts to cut, etc etc.
Then put away the pennies until your ready to sort the entire oil control system in one go?
Yes the engine is in the car and running without issues. The car is tuned with all of these issues in mind and is limitet to about 7200rpm. But I was thinking it would not hurt to have 25 year old gears swapped to new billet ones? Also putting on a fluidampr would help ease the stress of the pump?
Hmm that's a big job to pull the motor just to upgrade the pump and harmonic balancer. The average bear would probably bundle in more work at the same time, engine build or what have you. Your call though, suppose if your putting in all the work, your only paying for parts and machine work so I guess it's only costing you extra time in the end.
What type of rev limiter are you using at the moment and what is the type of driving your doing on the street that is making you concerned about the oil pump?
As for if it would hurt or not doing those upgrades, I suppose it's only going to hurt the wallet and/or your time in labour pulling the motor etc (provided the parts are installed correctly and to spec. Lots of things could hurt otherwise lol)
Im not pulling the engine for an oil pump, that is too excessive. I'll try to do it with the engine in the car, taking off the gearbox and sump.
I've also got the oem clutch so maybe I should upgrade that while in there.
Im not sure what type of rev limiter it is.. Didnt know there were different types of rev limiters? As for my driving, its only on the street doing a few pulls through the gears to about 7000rpm. Maybe a few launches if I feel like it. I also have a antilag/launch control button wich I know hammer alot on the gears.
I think we just solved this dilemma, oil pump upgrade is an engine out job. So can probably put a pin in this until your ready to pull the motor.
Ah yep, there are quite a few options with regards to your rev limiter. You can cut fuel, or spark or both. You can cut everything all at once and when you hit the limiter it's like hitting a brick wall lol. Or you can slowly introduce the cut, progressively cutting more cylinders over a RPM range, this style of rev limiter is really soft, kinda feels like the car has developed a misfire and just stops making power. No harsh cut at all.
Yeah well, I suppose we can all say stay away from the fun button until you've got all this sorted but you already know your playing with fire there lol.
  • Like 1
You are not removing the oil pump without pulling the engine. Just isn't happening. It is theoretically possible, in practice a 700 pound boat anchor is going to be hanging over your head and the slightest mistake will severely injure you.
I have done very annoying jobs that should require pulling the engine but I didn't. I get the mental block when it comes to pulling engines, especially because it requires a ton of shop space most people don't have. This is one case where you need to pull the engine.
I dont have the space or time to pull the engine unfortunately..
Ok so ill wait with the pump and gears. Would it be increasing the life of the pump/gears and worth the $ to just put a fluidampr on there while changing the timing belt which needs replacing soon anyway?
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
