Rez's R32 GTS-t Type M... presentable version!
Rezz - what are the offset number plate brackets worth, and who makes them?
I busted a bolt that holds the bracket to the centre support rail when taking the plate off for track day yesterday :P and that offset looks like a good solution... and where does it bolt to?
  • Replies 322
I busted a bolt that holds the bracket to the centre support rail when taking the plate off for track day yesterday :cheers: and that offset looks like a good solution... and where does it bolt to?
The bracket was about 2,000 yen (?) from SuperAutobacs (Ikeri's place :)) but I'm not sure who makes them... some generic company who gets their gear made offshore (China). It bolts to the bumper directly... just used self tappers to screw into the bumper from below.
You could knock up some stainless brackets at a steel fabrication place for about $5 though right? (DIY ;))
ronin, ask bass junky to make one up for you, he's a sheet metal fabricator.
failing that get a vice, pop down to bunning and get a piece of sheet metal and just bend it n drill it. real easy to do, and yeah as rezzeh said, get some self tappers to go in the bttom, or for more security, drill a hole in the bumper and put a bolt thru and a nut on the other side.
You could knock up some stainless brackets at a steel fabrication place for about $5 though right? (DIY :()
Thanks Rezz, was actually thinking of bending two pieces of aluminium strap and bolting them in... but I am a lazy bastard so will probably run around without a plate until the police get angry :D
I call him: T R A N S F O M A T I O N!transformation1.jpg
:bahaha: :bahaha: :bahaha: :bahaha:
V
Grand total? A$8,950... including car...
:looney:
hey rezz just wondering about what you did with the holes left over from the stock rear spoiler? does that mini back spoiler cover them?? i wouldnt think so but...
I went to Kounan (or some generic lifestyle/hardware center) and bought these little rubber round thingies that popped straight into the holes in the boot... instant fix. Troy knows what I'm talking about.
The Nismo rear spoiler doesn't cover any of the holes in the boot though, I just painted the round rubber things body colour, thats it.
that colour coding with the wheels and the bomex lip is horn.... :whip:
oh and what are the intercooler kits over there worth? I found the blitz kits to be far more expensive than the Greddy items.. (atleast on the soarer platform) any idea why this is?
You mean grommets :P
hey Justin, great car mate! just found this thread. Very understated, yet very tough, i like it a lot! :D
and to Justin/Troy, would you guys be able to hook me up with some parts i've been trying to get, but proving very difficult? I'd pay you guys a little somethin', somethin', and up front too, but i thought i'd ask first, and then go into detail (via PM) if it's possible. I can put some stuff on a container that i know of.
cheers!
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
