74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
oh crap I should have read the title...anyway I can't be bothered going to the DR30 one at the moment. I asked the wife and my sister and they both said that the DR was a muscle car...I think the HR is softer myself...whether its a GT or not I don't know...never thought about it, only know they have an rb20 in 'em (don't they?).
I reckon they're a GT, but I can't vote now cause I voted muscle car cause I never read it and I'm a dumb arse! :P
  • Replies 49
definately GT due to the weight. The gts-r looks aggressive and all but is heavy due to the HICAS 4 wheel steering system. I absolutely love HR30 rs-x's also. The power to weight ratio is amazing. Matt's car is the bomb!!!!!!!! you can make the 4dr versions of the r31 as aggressive as the hr31's. In a few months, mine will be a mechanical testiment hopefully
there are hr31 gts 4doors too:)
The HR is pretty weak to start with...takes a bit of work to make it as fun to drive as the dr but much prefer the rb over the fj personally, but would take a good dr30 over the hr31.
Answer, none of the above.
I was wondering how long it would take before someone piped up with that comment.
Gimme a Passage over a coupe any day.
Coupes just aren't pimp enough.
  • 4 months later...
I would say GT from the poll, but in actuality, Sporting Sedan (yeah, IMO the coupe can be called a sedan anyway, 2 door sedan) would be my description.
The GTS-R is a homologation special.
Ive owned an ausie R31 and have a HR31 GTS-X....stock the HR are fairly weak but get some mods happening and they are an angry engine....Im going with Muscle Car....just cous for the curves on the car are so aggressive compared to later skyrines - thats my personal thoughts
After having driven my brothers mate's HR31 i do not rate them!! They are a B O A T!!!
I definatly feel that they are more of a GT style of car then a sports car, kinda like how the later skylines i feel are classed.......Long range cruisers more then sprts cars
hell yeah! im gonna do that to mine when i get it, whether a passage or a local- dark, low, sweet sweet rims. mmm. if i wanted a coupe id getta r33 or something. which i would still prefer a four door variant...
Yeah.. I admit I love both the HR31's .. but to be honest, if it came down to a choice between R32 or R33 and HR31, I'd take the R32 all the time.
I have a Passage and R32, and they both have silvertops...the Passage is over 200kg heavier than the 32, and there is a big difference in the handling - it is nowhere near as nimble or point and shoot. The R32 feels like a sports car when you sit in it, and drive it - whereas the HR31's have a pretty different feel.
The Passage is very cool in it's own right, but more of a cruiser for the streets, not the track or the mountains. Might have good potential for drift though.
  • 4 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
