Spotted a Black C34 S2 on Mountain Hwy at about 7ish this evening. Flashed my lights and waved like crazy as we drove past one another, but the woman driving was completely oblivious.
... doesn't she know the rules of driving a stag?
spotted 6 stagea's today at the SAU Texikhana :) actually there was a 7th but he was parked ages away on the street :/
the only day that i didnt take my stagea there! god damn. drove my mates HOON r33 there.
Spotted zei20l's ex Stagea driving past my work a couple of minutes ago.
He must like it; it was actually clean!:nyaanyaa:
Did it sound like it was missing Dale?
Edited by PN-Mad
This is random but had to post. I dunno i guess it was a black Ferrari 360 modena or something travelling North on M1 past Springwood with number plate 34-ETA. Am i mistaken here, or does a Ferrari now need to advertise that it can beat a 34 ? What, can't catch a 35 ?
Edited by Jezboosted
had a laugh when someones mum (in back streets near kesters and bridge rd) told me not to park in her driveway cos she wanted to, (her son has white dayz fronted rs4s with white wheels and ms dolphin grille, me driving white stock fronted rs4 with black d1's and ms dolphin grille) wound down the window to say hi and we both had a chuckle. good on you mum.
2 s2's on north east rd near tolley rd last night between 6 and 7 pm, one yellow (spotto!) on the upbound and one white one with shiny wheels down bound then same upbound about 30 minutes later.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
