Was in WA caus my bro passed. Went to Augusta and at the Leeuwin Lighthouse spotted a bee u tee full N/A ARX. Saw the owner. He said it was one of only two that have been complied in Aus. Was only Stag I saw.
I was in a rental Camry. Which I must say was a quite half decent motor. (Racing to bathroom to wash mouth out)
White M35 ARX with roof racks leaving Jetts in Ringwood this morning.
I was in the black Pulsar who waited for you to to back out of your spot.
:action-smiley-069:
  • Like 1
:action-smiley-069:
Oh hello! :action-smiley-069:
Do you train there as well?
Not an ARX by the way!
Edited by Bmx537
Gah, I took a guess. I don't really know M35s. Thought I saw an ARX badge.
I'm out on the road most days for work so leave home early and train at the closest Jetts to my first appointment. I was in Mordialloc first thing so Ringwood was most convenient.
Shame I wasn't in the Stag this morning! Skippy saw to that. Fkn kangaroos.
Spotted a few Stagei (plural of Stagea?) at the Sakura Picnic last weekend.
Was shadowing the black M35 "JAPWGN" along the ring road for a while.
Check out my gallery from the day: http://www.sau.com.au/forums/gallery/album/5959-sakura-picnic-2016/
well, that would be me - on the way back to Canberra after having work done by Scott in Hampton Park last week - saw your car in Burke St - I lived in 115 Burke St last century and wanted tto see the house again but house has gone, replaced by town house- and I have a receipt for the car and all the papers. Your car looks good.
  • Like 1
Its all good, I have been a bit overly paranoid about leaving my car on the street as you could imagine.
Yea the house and commission built those three town houses last year. Before that they were empty blocks for years.
How long ago did you leave?
  • 3 weeks later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
