Fingers crossed for ya Troy, dicksons new thing is getting a different inspector the second or third time around and they deside to look for more that was missed on intial inspection to out do the other inspector and big note themselves, kind of a "so and so missed this and this, I have to do his job because he can't do it properly". Happened to 2 mates in the last few months.
if its a reinspection within the 30 days of the initial inspection they can not add more to the list, only check what was failed before, outside of that 30 days you are free game.
This is interesting I guess Troy can shed light on how he got done 2x?
Incorrect, they have a "do what I want and get away with it" stamp, I've done inspections and let stuff like tint slide by 2% and the car has then gone to Dickson for an ID check and they have crossed over my pass stamp and failed the car and edited my inspection slip and failed for tint and headlight aim... When it was just there for an "ID check".....
I have here the first ever commercially avaliable "Clapper" light switch! :D
Patent Pending.
It simply replaces an existing light switch so you can clap the lights on and off from the comfort of the couch! I've got a batch of 10 ready to solder up.
Richard. I'm off to the coast on sunday, but I'll have 2 ready for you if you want to pick them up tomorrow (saturday)?
Good question Zebdrew, maybe when the sun and warmth comes back out to play.
Yeah that's a good point lol
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
