Yeah this does that Bryce, I'll be going with a nice bilstein upgrade if it does turn out to be that.
I'm running Bilstein on all for now and thinking of changing to something else, I have been recommended Koni but I'm still thinking about it.
I'm still having tracking (wondering) problems, I've spent 3K on the front end plus some on the rear, had all experts play with it, i.e. Inline & Capital Steer & Susp ... Changed all four tyres (which did make a huge difference) .. now I've been advised to go with Koni shocks!!
I'm not an expert so I'm being guided buy those who say they are :closedeyes:
BTW on tramlining....
if you've been spending money on front end bushes, while it can be expensive it's not wasted money IMO. Bushes wear and these cars sure aint new any more. I'm assuming you've change the caster rod bushes and upper control arm ones. there might also be a bush in the steering column, I'm not sure in the 34. there are also steering rack bushes and inner and outer tie rod ends.
if you've done all those, one thing that surprised me in my 33 was how much worse wide and sticky tyres are for tramlining. what size and brand/model of tyres are on the front?
oh and shocks have no impact on suspension or tracking in a double wishbone setup like skylines. the wheel would travel through exactly the same angles even if the shock didn't exist. most cars run strut front suspension where it does make a difference
Re above ^^^ . note to all,
If anyone has any thoughts or something to contribute I'd be happy to hear it, all contributions will be appreciated :rolleyes:
Balljoints, Tierods / ends, Steering Rack / Bushes / Bolts, Control arm Bushes, Wheel Bearings, Alignment, tyre pressure / width...
All things I'm going thru to stop the Wagz bump steering / tram lining.
All been done, most replaced :yes:
Then all checked by both Chris at Inline and (forget his name) .. the guy who owns Capital Steering and Suspension, no one can find anything wrong.
Edited by THE34T
Wheel track makes a big difference. As in how wide they are.
And its just the way it is, if you want wide wheels.
You could probably compensate/compromise to some degree with settings, but you need adjusty bits for that.
Mines bent and adjusted, it feels ok.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
