Hey People
I just replace my turbo with a Hi-flowed and VG-30 rear.
I added:
Z32
FR
Exhaust Cam
Hi-flow Cat
My older mods:
FMIC
BC
Walbro 255L
Split dump
Apexi Power FC
3" Exhuast Tip
16 PSI
With a phat 261RWKW
Tuned by Cool Ben at Unique Autosports.
posting this for UCD15R33
251kw/336hp
stock motor
stock injectors (maxed at this boost level, normally only running 8psi until new injectors)
stock manifolds
stock afm (maxed
emanage ultimate piggybacked off remapped ecu (with only a basic tune, waiting for bigger injectors in a week or 2)
BCPR6ES plugs gapped at 0.8mm (needed to be gapped down as it is breaking down, as you can see on the dyno graph)
bellmouth dump/front pipe, new 3" cat (the last one collapsed and we only ran 291hp at open boost), 3.5" catback
greddy m-spec cooler (the ones on special in the latest autobarn catalogue) with custom piping
turbosmart manual boost controller
Garret gt3076r (IW, 0.64 rear housing) boost can be see on the graph
K&N panel filter (took it off and ran 10hp less with no air filter)
New figures:
RB25DET
Stock bar 1.8mm Tomei head gasket and ARP head stud and nut kit
GT35R
Motec M800
Nismo 740 injectors
546@fly 460@wheels 1.7bar pump fuel
592.7@fly 500@wheels 1.8bar race fuel
Be careful, these engines suffer badly from surge on track. We have just killed ours.
hey, my s2 r33 with :
stock motor, injectors, ecu, afm, turbo
splitfire coil packs
full exhaust 3in turbo back, standard cat
fmic
bosch044 pump
pod filter
213rwkw on 11 psi.
Edited by Fadie
RB25DET Unopened Regulary Maintained
HKS GT-RS
Power FC ECU with HC
and heaps of other little bits and peices.
255rwkw @ 1 bar (14.22psi) On a safe tune.
Powercurve turned out very Linear as expected, see peak power at 6500rpm approx, Car is very nice to drive, has a sports car feel still. Initial surge is torquey and the pickup is seat hugging. because of the Linear powercurve, traction is managable
Big thanks to Dale_FZ1, Sydneykid, FineLine, ShaneF, wrxhoon, 3lit3_32, MR331307 and anyone else I have missed, That have lent advice and information to me and helped me over the last 12 months regarding my setup. Much appreciated. :unsure:
This is the First tune. with more to come
Edited by silverbulletR33
Hey Guys,
Been a long time coming, but here it is.
96 R33 Series II GTS-T
Full "jap" parted, forged bottom end/ head work
HKS GTRS Turbo
HKS Step 1 Cams
Hks Cam wheel
Dump/ Front Pipe & 3 inch straight through exhaust
Apex-i Power FC
Apex-i AVC-R
Nismo 555cc Injectors
Bosch Fuel Pump
N1 Oil Feed & Water Pump
Plus more that i've forgotten i'm sure
We did have it putting out more, but i was happy to leave it here for now.
271rwkw @19Psi
I'm a little dissapointed, i thought with these mods it may have made more at that kind of boost, whats your thoughts??
Oh, and by the way, she is up for sale if you want more info.......
Edited by DRAGTS
RB25DET
HKS GT2535
Power FC, with add on boost controller
S15 450cc injectors (max now about 80%)
Tomei fuel pump
Z32 AFM
18psi/1.3bar (dropping back to 16psi)
Tuner - The Hitman (penrith)
Max was 249rwkws but missing and popping so he dropped 1 degree in timing for a smoother result.
Also had to regap plugs to 0.65 to prevent missing/coil pack symptoms....which worked a treat ;)
Final result was 245.9rwkws, goes HARD !
Edited by Birnie
Up-dated dyno results.
Now with:
Highflowed BB turbo with op6 housing
Tomei Poncams
Nismo 555 injectors
Z32 AFM
Boost was set at 15psi and made 250rwkw
Seems like alot of guys are getting 250 with stock cams,i wonder if the poncams were worth the money.
Blue line is high boost red is low.
Looks pretty smooth to me.
R33 S1 GTS-t
rebuilt motor
fully balanced bottom end
CP forged pistons
k&n pod filter with CAI
3.5" turbo back exhaust + high flow cat
front mount intercooler
bleed valve boost controller
bosch 040 fuel pump
apex power fc
with these mods i made 201kw @ 12psi (dyno in sig) on a safe tune
ive recently got -
nismo fuel pressure reg
Z32 air flow meter + tomei plug
hiflowed turbo
it should all be fitted up and tuned in the next few weeks, so ill post up my results :D
Stock RB25
stock gasket
stock cams
stock intake/TB
HKS log manifold
TO4e
399.3 RWHP
Can anybody tell me what that is in Kw?
Also, any guess what that would do in the 1/4 with drag radials? This is in a R32 BTW.
R33GTST S1 Stock RB25DET
Apexi pod
z32 AFM
Slide stage 3 hi-flow
Turbotech MBC
FMIC
Walboro pump
555cc injectors
split front/dump
3" turbo back
PFC
263rwkw @ 18psi
Tuned by Mick O'Shea at Signature Performance
r32 gtst with rb25det
gt2835r garrett
3 inch exaust
z32 air flow
550 tomei injectors
500 hp uas fuel pump
power fc
running 17 psi
tuned by unigroup
made 257kw atw's
i'd post a pic if i had a camera at the time
1992 R32 Gtst M-spec.
1993 R33 s1 RB25DET Conversion.
- Stock internals.
- Garret GT30 / 71R ball bearing turbo.
- Front mount (300 x 600 x 76mm).
- Sard 550cc injectors.
- Power FC.
- Bosch 040 pump.
- Splitfire coils, NGK iridium plugs.
- 3" mandrel exhaust, dump pipe - 3.5" metal cat
- Turbotech manual boost control
= 230.5rwkw, 550nm torque at 18psi
Going for 250rwkw from next tune, with Z32 afm and Cam gears.
1993 S1 R33 GTS-t
- HKS 2535 @ 17psi
- HKS Front Mount
- Nismo 555cc injectors.
- RB20det remap with VCT Controller.
- Bosch 040 pump.
- Splitfire coils, NGK copper plugs
- 3" mandrel exhaust, JJ Split dump pipe - 3" magnaflow cat
- Turbotech manual bleed valve
= 241.4rwkw, 711nm @ 116kph
Dyno graph to come
Big thanks to Dr.Drift for the tune, also to acsplit for his help with taking all the bullshit off the car, and getting it sorted!
231 rwk on 16psi
r33 gtst with
slide hiflow turbo
tomei pump
pfc
fmic
600cc hiflowed injectors
z32afm
3" turbo back exhaust
hks actuator
**turbo blew so back to stock turbo on 10psi.**
Edited by R33GOD
Engine management - PFC
Boost ran - 18psi
Turbo - Garrett GT3076r
Nismo 740cc injectors
Bosch 040 pump
Gready EBC Profec II
Z32 80mm Air Flow Meter
Hybrid Intercooler
3inch Exhaust turbo back
Splitfire Coil Packs
Stock Internals
no head work
Fuel pump
250rwkws on a low reading dyno fullboost @ 3500rpm
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
