R34 RB25 Neo
FMIC
Oil Cooler
Engine Earthing
Pod Filter
Blitz DSBC
Type 3 BOV
Apexi AX75F82 turbo
Stainless steel exhaust manifold
3" turbo back exhaust
Z32 Afm
480cc Injectors
Bigger Fuel Pump - Unknown
Apexi PFC
100 Octane
261.3rwkw - 1bar(14.7psi) - 350rwhp
243rwkw - 0.8bar(11.5psi) - 327rwhp
234rwkw - 0.6bar(8psi) - 313.7rwhp
Hi all, just got everything done and dyno tuned on my car. Here it is:
R33 GTS-T (RB-25)
Mods:
HKS GT2835 Pro S 0.68 A/R Turbo
GReddy Front Mount intercooler
Nismo 555cc Injectors
Bosch 040 Fuel Pump
3.5 inch straight through exhaust with split dump
Power FC
Z32 AFM
Cold air intake with pod filter and heatshield
Splitfire coilpacks
Platinum spark plugs
272.3 RWKW at 18 PSI
Edited by Turbz RB-25
R34 GT-T (NEO) '98 Manual
Stock Turbo
Greddy FMIC
Greddy Profec B EBC
Walbro Fuel Pump
Nismo 480CC Injectors
Greddy E-manage Ultimate
Z32 AFM
3 inch AM performance front/dump, high flow cat, 3 inch zaust.
Apexi Intake
208.3kw @ wheels on 12 psi on a 40 degree day.
Stock Turbo
Greddy Profec B Spec II (11psi)
Metal cat & HKS Cat back exhaust (No Dump pipe yet)
K&N Pod Filter
184.1 KW @ Rear Wheels - 11 psi
175.4 KW @ Rear Wheels - 7-8 psi (Stock Boost)
Edited by R33Turbo
R33 GTST S2
Stock internals/unopened
Power FC
HKS GTRS turbo
Blitz LM FMIC
3.5" turbo back exhaust, Metalcat convertor
Solid piping mod AFM > turbo (rev210's intake mod)
550cc Nismo injectors
Nismo fuel pump
Z32 AFM
Stock BOV modded to suit
STOCK AIRBOX
256rwkw on 16.5 PSI (High boost)
241rwkw on 12.5 PSI (Low boost)
The dyno chart maximum was from a run with a modified airbox, but only got 3kw extra, so no point. Line below that is how it stands. The lower line is on low boost.
Edited by sl33py
1995 R33 GTS-T Series 2
Apexi Power FC
GCG High Flow Turbo
TurboTech Manual Boost Controller <-- so good
FMIC
Apexi Panal Filter inside stock airbox
Stock AFM
Stock Injectors
Walbro 500hp fuel pump
3" Turbo Back Xforce Exhaust Stainless Steel
Stock Internals
Manual
221.5rwkw @ 15psi (300rwhp)
car has air and exhaust restriction somewhere will be fixed and retuned looking for 240rwkws...
R33 skyline RB25DET
Garrett GT3076R
Apexi Power FC
Z32 Afm
FMIC
Tomei Fuel pump
Greddy profec b spec 2
Apexi power intake
HKS super drager exhaust turbo back
Made 233 rwkw which is 310 rwhp on 17 psi full boost by 3800 rpm. Was aiming for 250 rwkw though not sure what went wrong.
Edited by SexyPete
This was a quick touch up tune for Texi after running in the engine.... proper tune with more boost in 2 weeks - stay tuned!!
R33 S1 Skyline
Garrett GT35R - 0.63 rear externally gated (0.82 on standby, just want to max this rear out first )
6boost manifold
38mm turbosmart ultragate (needs to be upgraded if keeping the smaller rear housing on)
3" exhaust with metalcat - proper mufflers, no cannons....lol
Greddy E-01 boost controller
550cc injectors (740cc nismo's on standby)
Haltech E11V2 - wideband 02 and display also installed
greddy intake
rebuilt engine - forged internals 20thou oversize - 4,000 odd kms old - Rebuilt by Dave aka T04GTR *shameless plug :laugh:
Some little tricks done to the head - wouldn't tell me :(
Step 1 poncams
FMIC
Walbro 255 (044 being installed prior to final tune)
Sard FPR
94 r33 gtst
Engine
Standard internals
gt3076r 0.63 rear - high boost is 300kw @18psi :D
low boost is 250kw @ 13.5psi
on a chassis dynapack dyno (low humidity, 22 degree day)
greddy profec B electronic boost controller
standard injectors, running at 75% duty cycle
sard fuel reg
bosch 044 fuel pump
z32 afm
splitfire coilpacks
haltech e11v2
hybrid front mount intercooler
apexi pod filter in custom box
maganflow 3 inch turbo back exhaust, with high flow cat and hi-tech resonator
car is a bit laggy, but incredibly fun once it gets going. probably get some cams in the future
bit late.....got my setup mildy tuned about 2mths ago by matty spry. LEGEND.
garrett 3540
z32
3'' zorst.
pfc
and secret parts :D
exedy carbon-d twin plate clutch with lightened ventilated billet flywheel
got me 385.8hp
not game to go higher without pistons. prefer to have it safe and thrash it. than to have 400+hp and break it when i floor it for the 1st time.
Edited by r33cruiser
With so many threads about turbo upgrades for RB25's i thought itd be a good idea to start a thread that shows results only, as the results from various threads are scattered everywhere. Everyone has there own ideas about what power they want so obviously there isnt ONE perfect turbo upgrade for everyone.
Please post your RB25 dyno graphs only and state the following:
-Engine management
-Boost ran
-Fuel used (pump or special)
-significant engine mods (eg cams)
The idea of this thread is to be a quick reference to various turbo's performances on RB25's, not to be a discussion thread.
Thanks
(If this has been done already let me know, but didnt come up one in search.)
1993 R33 GTST s1
Power FC
Z32
Stock 370cc injectors
Stock internals
GT3071 Internal gate @15psi Boost (comes on at the same rpm as stock turbo!!!)
Bosch 044
Splitfire Coilpacks
Greddy Type M FMIC
Bp Ultimate
X Force 3 inch turbo back
Profec B (turbo wastegate is 15psi so couldnt use teh Boost controller as the injectors were maxed out)
235.4kW Atw
R33 GTSt 93 model
Apexi pod & box
z32 AFM
slide hi-flow turbo
FMIC
Nismo 555cc injectors
Greddy Profec II boost controller
Apexi powerFC
3 inch front and dump pipe
3 inch hi-flow cat
3 inch Nismo cat back
235.8rwkw @ 15psi - all work done by Unigroup :)
cough upgraded copugh :)
Same mods minus the blown hi-flow.....
now with GT-RS fitted and tuned, again, by Unigroup :D
187.9kw @ 6700rpm
1996 R33 Skyline GTS25t
600x300x76 FMIC (China)
JustJap Racing Split Front/Dump
JustJap Racing De-Cat Pipe
Full 3.5" TRUST Cat Back
Manual Boost Controller @ 10PSI
Pod Filter
SAFC Neo
Was hoping for a little closer to 200kwkw, but the Neo is a pretty rough tool, so hopefully a Power FC will see that goal come a little closer.
RB25DET S2 R33 Skyline
Standard Turbo/injectors/ Fuel pump
Blitz FMIC
K&N Panel Filter
3 inch dump Hi flow Cat
Kakimoto cat back
Gizzmo EBC @10.5psi
Power FC
201.1rwkw
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
