This is for those of us that attended the LS1/Skyline dyno day, & saw/heard Martin's Soarer make 281rwkw on stock turbos.
I can confirm that they are/were indeed stock unmodified CT12A's (well the one I played with was).
More amazing is that the turbo I had a look @ was in pretty damn good condition, considering it would've had a hard life!
I still can't believe how well they held up to 3.0bar of boost on the dyno day (ok so I made that bit up :P)
https://www.sau.com.au/forums/topic/5639-martins-soarer-turbos/
Martin,
Liked the story in HPI this month. Was spun out by the difference the new pipework made on the twin.
Quick question: Why is HPI so damn expensive and so thin?
Didn't renew my Hot4's subscription, no matter how many shirts and vids they tried to feed me but christ....9 bux?
i know...i'm cheap...
  • 3 weeks later...
  • 3 weeks later...
Originally posted by -Joel-
did u see the way that 7ltr manaro pulled down the straights.. OMG... :eek:
wow... I hope he drives it the way they are supposed to be driven and not limp it every where... :P
Ah nothing like a Full Blown Factory Sports-Sedan,,,,Good-bye Nations Cup,,,,.
Bathurst 24 Hour 2002,,,,No Vipers,,,No,,,Mustangs,,,No Lambos,,,and one Ferrari,,,
Procar YOU should be ashamed of yourselves....
Neil.
The way its going there will be no genuine HRT 427, which means I wont be having one. That saves me from the biggest personal loan known to mankind!
Good news on the Soarer is that it makes 322rwkw at 1.3 bar with its new turbo. Cant wait for the next dyno day! Its sort of a Skyline now too, as it has R34 GTR rims.
Martin, how does it launch now? Can you still compete in the traffic light 0-100??
I ran a black 33 the other night (i think it had silver/grey Zeni Tani sticker on side) and i killed him 0-100 off the line, then i back off-we're in a 60 zone- and then he comes screaming past (had an external gate or screamer pipe, which by the way i didnt think sounded very nice!)
What do you guys think of these cars with massive peak power, but that cant give a decent run off the line?? I dont see that as being very fun!
That said, i have 200rwkw, but need a few extra! Had trouble holding off a pack of 180's last night on anzac, and those buggers were launching awesome too!
Martin, also, can i get you to tune my car through tilbrooks? Do i just ring up and say i want you to do it?? And can i get a dump pipe of same design as your soarer ones on the TT setup? -i still have the cast factory dump.
gimme a price and ill be there, cheers.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
