i don't suppose you know the episode that was in?
anyway mine...
"skylines are so passe"
yes, i've also had the "skylines suck"
"skylines don't have any torque" to which i replied "do you even know what torque is?" ... "it's it's it's it's er it's um"
mmm that brakes exploding thing is doing my head in... i dont understand that at all =
Agreed that a lot of people have skylines, but its for a reason - they are decent cars - 5 billion p platers cant be wrong.
the torque thing i agree with when it comes to the RB20... i cant stand the torque curve of the Rb20 motor, but they are quite robust and cheap to replace....
  • Replies 635
[12:08:24 AM] CrazySexyCoo: skylines are so passe
[12:09:13 AM] ::: sam :::: **** passe... cars are more than a fashion
statement to car enthusiests
and yes, i am quite proud of my response
jeremy clarkson says a lot of weird things on his show that the audience is supposed to just accept.
what do u mean about torque curve? i got 627Nm of torque :)
To be honest the only reason I bought a Skyline is the potential + it is a new style interioir car.
After owning the VS 5ltr 5speed I looked at buying a VLT.
I couldn't bring my self to step back in to the old style interior.
I checked out the R32 skyline. It was good on fuel went ok for a stocker, motor, diff & gearbox are strong (unlike the VS when it came to the diff & gearbox) and had plenty of potential.
Steady mate. I was agreeing with you, but you would probably consider me an "old fart". We aren't all tarred with the same brush you know.
Nah your not old mate id consider over 60 to be the age where you would start going stupid
that was my intended OLD FART AGE BRACKET
you still have 15 years to go, but as your a fellow skyline driver the time will fly very fast (but only on the track) :thumbsup:
The guy on top gear saying that R32 GTRs brakes sometimes explode!
I don't remember that, he does exagerate a lot though, it's part comedy remember, see the review on the monaro, and when he turned the traction control off the car would yell out "You bloody poofta"
*Things idiots say about skylines*: "Anything from the mass media"
hahaha i loved that. i had people from other countries on car video forums pming me with "What does "Puffter" mean?"
anyway back on topic :thumbsup:
PUBLIC ENEMY #1?
It certainly looks like this is where the Skyline is heading in NSW, thanks to a minority of idiots that like driving at 4 times the speed limit etc, etc.
The Skyline is just one of a couple of makes being targeted by our poleticians to be banned from being driven by under 25 driver's and particularly "P" licence holders.
Anybody got any suggestions on how to combat this problem?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
