Hi All,
I have been trying to make some improvements to the R32 GT-R Workshop Manual PDF that's floating around as I find its pretty unusable in digital form.
Anyway, after a couple of hours work I give you the improved workshop manual with rather complete bookmarks (make sure you open the bookmark tab in Acrobat) :D
Download the Zipped PDF (~21Mb)
Mirror by Amaru: http://gtr.infinite.net.au/lw_gtr_32_servi...vice_manual.zip
Not sure how long I can keep it available as it will depend on bandwidth. If others want to host mirrors, that would be great.
Let me know if you find any mistakes and I will try and fix them ASAP and reupload.
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/68078-improved-r32-gt-r-workshop-manual/
  • Replies 42
is there any software around to traslate the picture to text? like you can do if you scan a document.
The problem is that, unfortunately, the manual was scanned as a series of images rather than using Optical Character Recognition (OCR) which would have made all the text portions appear as just that, text. As a side bonus, that would mean the text is searchable, selectable, copyable, etc etc.
I just tested exporting the PDF to image and running it through some OCR software. It seems to work OK, but will take a considerable amount of time to process. I will have a fiddle and see what I can do.
Richiarid :D No problems.
Lucien.
Hi Guys,
Your all very welcome. I hope you find it useful. Its nice to give something back (that people appreciate :D) to the community that's given me so much :grouphug:
Anyhoo, after trying to latest version of OmniPage (and OCR package) it seems it can import directly from PDF. I have experimented with it a little and it will still be quite an effort to swap it over from images to text, but give me a little time and I will see what I can do.
Lucien.
nice job matey....... it has help me out a hell of alot with my rb conversion in my 66 gt........ much appreciated .... good to see some decent people out there!
cheers.... :D
Ok,
I have spent the better part of the day trying to process the workshop manual with OmniPage. I have managed to get 100 pages done (so approximately 1/8th of the manual):
I would be interested to see if people think having text and images (rather than just a series of images) is useful -- ie. the text is now fully searchable. If you have a minute, feel free to download the 100 page "sample" and have a play with it. If people think its worthwhile, I will keep going and try and do the lot.
Sample is here (~9.5Mb): http://ugbox.net/~lance/OCAU/lw/R32_WM_Rev2_Test.zip
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
