Off topic, but i've been recommend to try this by stagefumer11:
"ok this is a easy fix you need to turn down you full lock stopers.
you will find on the lower control arms, on the end. is a adjustment screew when you can adjust the full lock stoppers. if you have a look you will see what i mean. Its a small bolt with a lock nut also. turn these in to turn the lock less.
DO both sides as you can stress you steering rack if they arnt even. Get it pretty close and you will be fine. Also put a layer of grease on to the rubbing points, as going over bumps on full lock can be quite embarrising"
Skyline model = HR31
Wheel diameter = 17"
Wheel width = 8F/9R"
Wheel offset = +30F/+32R
Tyre size = 235/40-F 255/45-R
Stud Patern= 114.3
Modifications to fit = lose the plastic inner guards. (also have 5 stud hubs which alter the offset out about 3mm)
Hey guys, I've got stockers w/225/50/16's. But I Bolted up my mates BBS rims this arvo, may buy them off him. . .
Skyline model = R33 Gts-t
Wheel diameter = 18"
Wheel width = 8.5"
Wheel offset = +40
Tyre size = 235/40-F 265/35-R
Stud Patern= 5 * 114.3
Modifications to fit = None yet, they seem to rub at full lock on the front, parking etc, and only clear the stock front brake calipers by ~ 2mm, haven't done enough driving on them yet. . .
Anyone see any problems with this size?
I'm surprised they fit at the back to be honest.
Thanks
Interstin... dads 33 has 235/40 wit 8' wide on front and 265/35 wit 9' wide on the rear with no problems at all, gaurds havnt been rolled either... So i cant see any problems? Maybe your offset is slightly different though!
Hey jazza08, they seem ok and only one of the fronts rubs (I only have one inner guard liner), I think the offset is actually the same as the standard wheels, cos they are marked '16*6.5JJR16 40'.
Speaking to another 'Line owner this evening he reckons he used to run ten inches out back . . . No mods. . . B)
Ive seen 265s on a 10' wide rim before in a car mag, never in real life. I doubt 275s would fit with everything standard?
If you take our ur guard liner (i believe our 33 still has them) that may help also! Nothin too much to worry about unless it rubs real hard of course :)
Hey guys,
I am looking at putting a set of 19x8.5" on the front, and 19x9.5" rears on a GTS-T R33... Is this possible with maybe only lippping, or would some more extensive mods need to be made? Is this all the info you would need to answer that question too, or does the offset play a major difference?
If anyone knows I would appreciate the info.
Cheers.
woah! 17X7? I think they were designe for a FWD car like a pulsar or something as even standard R32 GTR wheels are 8 inch wide, and most 17 inch wheels for 32 GTR are 9 inch or 9.5 inch. it must look quite strange with such narrow rims on it. actually from looking at the tyre size are you sure they are 7 inch wide? any pics?
haven't looked at this thread in a while...
hmm, maybe they are 17x9's then...they don't look thin and I don't actually know where I got 17x7 from :). I will try and get a measurement myself if I can.
Hey Cowie, you have Circular wheels :), wow!..... :)
Skyline model = R32 GTR
Wheel width = 9.5"
Wheel offset = +14
Tyre size = 245/40 All 4's
Modifications to fit = None. But if i lower it more then i might have to lip the guards
I have seen 17x8's on most 33's in this thread have offsets of 32-36. If a set of 17x8's with an offset of say +45 are fitted to an R33, they would sit further into the guard, right?
Yes but more importantly the spokes would probably not clear the brake calipers at the front of the 33s.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
