Wheel Sizes & Offsets For Skylines
how many mm spacers? Does the guards need to be rolled? Thanks agian
If it was my car I would be running a 20mm bolt on and flaring and down sizing the tyres to fit. Assuming the rear guards are very similar to that of a r33. I believe rolling is a must do for any wheels you buy, but yes I do think it will need to be done.
But to get them to fit with out alot of major work best way to work out what you will require is to use washers stacked on top of each other on your studs till the wheel no longer fouls on anything, then measure the width of the stack and get spacers the same width.
Neil
Edited by mr_squiggle_1
Neil
hmm never thaought of uding the washers before to measure the spacers needed. Good tip!! Will try that. So i guess once i got the rims and before i go out and buy some wheels i will need to figure out the spacers first?
Hi Guys
Just a thought about branded rims available, i notice Breytons or Carllson rims looks really nice on Continental car like the Mercs or BMW. Are the offset the same to fit an R34 GTT since they also hv 5 lug. Notice the Lexus do share the same sets as the conti's though Wald is a Jap brand. http://www.wald.co.jp/news/back/200706/sab/s33c_2/index.html
Appreciate feedback.
hmm never thaought of uding the washers before to measure the spacers needed. Good tip!! Will try that. So i guess once i got the rims and before i go out and buy some TYRES i will need to figure out the spacers first?
I have modified your post to what I think you meant.
But yes once you have the rims jack the car up, put it on stands and work out what spacer your going to need. To get the wheel up to a similar point to where it will sit when on the ground, use another jack under the rim, throw a rag between the wheel and jack to protect the wheel. That way you can work out the amount of stretch and flare required or not required. Id dare say you may be able to fit the 10 with out any work possibly.
Again if this was me fitting them the 10's would be recieving 235 tyres and spacers to get the stretched tyre to just clear the guard lip, this method will require less guard work then running bigger tyres and have the wheel itself outside the car more (the look I like). I have noticed however on this site that people tend to use bigger tyres then I would, ie 265 on a 10 etc.
Its all up to you and the look you want,
Neil
Neil
opps sorry for the confusion. Yea what i mean are the tyres. As for the rims sizes, i was just actually following what the hyper rev mag refers at the stagea demo cars. But the offset is little bit different. Yea i will certainly try the method you mentioned before i go out and buy spacers and tyres needed.
Im planning to use the Sumitomo HTRZ2 tyres. Pretty good price for them too. Not much difference from Nexen in terms of price wise.
I have some questions for those with 33's. Im hoping to fit some 18 x 10 +20 on the rear of my newly acquired 1998 series 2. But I need to know the inner clearance available. The 10's according to my calculations are going to go back over 234mm from the hub face. Im no concerned with the distance out over from the hub, I expect to have guard work to fit them (dont believe in buying wheels that dont need work to fit). Just need to know if the inner clearance is big enough.
Hopefully some one can have a look/take some measurements for me,
Neil
Hi Guys
This may sound a bit odd but...
Has anyone tried R34 GTT rims (7.5x17 e40) to R32 GT-R?
Also i understand that GTT has these rims all aroud - confirm or correct me please.
On paper it looks like they may fit but i´m little unsure
TIA
  • 3 weeks later...
I have a 1990 Nissan skyline GTS-T Type M
I am getting a staggered set-sup, and DO NOT understand offset...
I am getting 18x8.5 front and 18x9.5 rear
I dont have my rear fenders rolled. any suggestions on wat offest I should go with front? and rear?
Thanks very much
Well just fitted some new wheels to my GTR
Skyline model = R32 GTR
Wheel diameter = 18in
Wheel width = 10in
Wheel offset =+18
Tyre size = 265/35
Modifications to fit = Rears are rolled but i think the wheels maybe rub still with to much weight in the back
Thanks very much
the rears will need to be rolled regardless of the offset, 9.5 is a very wide rim, if u get enough stretch on your tyres you might JUST tuck +30 under the guard but i would get something like a 17x9 +17 or something like that would look alot tougher :)
Wheel width = 9.5
Wheel offset =+12
Tyre size = 265/35
Modifications to fit = Rolled the rears, remove the front liners and bent the tabs in.
they still dont fit right, the rears stick out past the guards, so not legal :D
http://www.skylinesaustralia.com/forums/Jd...in-t205654.html
I am looking at buying a set of these wheels for my R33gtst, by looking through this thread I see that 8.5 x 18 are generally offset +30 front and +38 rear but cant seem to judge if 9.5s would be the same or if they are even a good option. Can anyone shed some light for me?
Skyline model = R33 GTST
front
Starcorp rim
Wheel diameter = 18"
Wheel width = 8.5"
Wheel offset = 38mm
Tyre size = 235 x 40 x 18
Modifications to fit = nil - plastic insert still installed. Height of the car is ~355mm centre of wheel to guard (SK's kit)
rear
starcorp rim
Wheel width = 9.5"
Wheel offset = 38mm
Tyre size = 265 x 35 x 18
Modifications to fit = needed to roll the rear guards to prevent scrape. Height of car ~345mm centre of wheel to guard
standard brakes front and rear.
interesting that even when it was 15mm lower than the current height it never scraped with the Cusco coilovers (8kg/mm rear), it's just that all my fillings fell out.
cheers
Thanks very much
around +40 should put the wheels pretty much dead on with the guards with around -1 degree of camber, if running a 255+ you may need a guard roll. with 18's you can go higher offset at the rear as it will clear the rear toe arms unlike 17's. for the front i would run around a +30 to be safe, around that kind of inner clearance ur looking at fouling issue with the upper control arm.
what u guys reckon about this.. 18x9.5 +17 for r32 gtst?
i have 17x9 +30 at the moment front tyres are 225 and rears are 255 and i have no problems at all!
cheers
if your game for some guard pulling go for it, this is a 17x9 +16 with a 225/45 and -2.5ish camber, if you run a 225/45 on the 9.5" u should be able to make it with a decent roll and -2ish camber.
heres the 17x9 +17:
http://img524.imageshack.us/img524/9894/dscn9843mr0.jpg
Skyline model = 1989 S3 R31 sedan
Front wheels = Custom Made ROH adrenalin 3 piece wheel
Wheel width = 9"
Wheel offset = +/- 0, now with 25 mm bolt on spacer, so effectivly -25
Tyre size = 215 x 45 x 18
Modifications to fit = Heavily flared front guards done with roller (2 inch flare) 3 deg camber (S13 coilovers), stretched tyres, 10KG front spring rate
Rear wheels = Custom Made ROH adrenalin 3 piece
Wheel width = 10"
Wheel offset = +5
Tyre size = 225 x 45 x 18
Modifications to fit = Even Heavier flared guards done with 20 pound hammer, and copious amounts of fibreglass and filler/ 8KG rear coilovers with dampners wound up, super stretched tyres.
Car is very low, and Id have maybe 3-5mm clearence on the rears, a little more on the front. But she still doesnt scrape anywhere.
Thanks very much
I have 19x8.5 +35 front with a 235 tyre, fits nicely, i do how ever have rolled guards.
Rears are 19x9.5 +38 with 265 tyres and rolled guards. I may get the rears guards slightly pumped so that i can lower it a little bit more.
Edited by SNISMO
