hey guys, looking to get some wheels for my 32gtr, i understand you shouldnt run staggered sizing but how important is it that offset be exact? The wheels im keen on are 18x10 +10 and 18*10+4
As long as rolling diameter is the same it should be fine. Those wheels will stick out of the guards unless you run and negative camber.
Just copy and fill in the table;
Skyline model = R33 GTST
Wheel diameter = 18"
Wheel width = 10.5"
Wheel offset = 38
Tyre size = 265/35/18
Modifications to fit = fark all
please display a picture of te37 with that offset as im not too sure on what it is
Edited by DAV33R
18x9.5 + 30 will be safe. 18x8+15ish for fronts.. But I would just run 9.5+30 all round IMO. I am running 9.5+20 all round with no issues (but I am poking outside guards)
Edited by sleptema
Hello SAU, newbie here needing help. long story short, uncle is selling twin turbs BeeMerW and said that if his aftermarket 20"s that he had on it would fit my N/A 34 25GT, then i could have them. I'd just like to know if they would fit and if i needed to roll guards or adjust camber or anything like that. Also, if i would be able to lower the car if they did fit. I'm not condoning 20's on GT's but hey theyre free and have brand new low profile tred to go with them. Tried searching to find an answer but not really any luck, any help is much appreciated thankyou all in advance :cheers:
I'll probably just get the wheels off him when he's done with them, I just wanted to know if I would need to roll guards or anything like that
Listen to niZmO_Man, please, for the love of god.
He knows much more than you. Don't take what he said, then debate it.
Skyline model = R32 GTST
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +22
Tyre size = 235/45/17
Modifications to fit = Guards lipped prior to me owning so i can't really comment, scrub might be an issue if you are low, however i have no scrub problems
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
