Hey guys,
been looking through this thread and other forums for ages trying to decide on a good wheel fitment for an r33 s2 gtst. Seems like 18x9 +20 would be a decent fit for an r33 all around flush fitment that wont foul suspension and can be cambered in to prevent scrubbing on guard liners. Have seen examples of this size in a set of work xd9s (dontyellpl0x) and a set of rota grids (boosted_andy). Would consider anything similar to 18x9.5+30 but it seems that at this wheel size its a bit hit and miss whether or not it will foul suspension/brakes. What wheels are still being made in 18x9+20 (grids and xd9s/d9rs not available in this size anymore) or 18x9.5+30 which dont foul brakes? Dont want to mess with spacers.Want to run 235/40 all around. All guards already rolled ,dont want to bin guard liner.
Cheers guys.
Edited by onthesuss
  • Like 1
Hey guys,
Cheers guys.
9.5+30 will fit.
Will the car be low? If so you are better to lip the front guards
Hey guys,
Cheers guys.
235 is too small for 9.5 and marginal for 9in.
Hi guys,
I'm looking to pickup a set of these wheels in 18x9 for my R34 GTT:
http://marsperformance.com.au/MARS-MP-37-4x-18-Inch-Matt-Bronze-Alloy-Wheels-Rims-5-x-1143
I don't believe the car is lowered and I would prefer to not roll the guards. These are the tyres I'm looking to fit:
https://www.tyresales.com.au/buy/tyre/kumho/ecsta_le_sport_ku39/235-40r18/1383?q=4
The offset available for the wheels is 15mm and 22mm.
What wheel sizes should I order in order to get a flush fit without having to roll the guards? Will the 235/40/R18 also fit properly?
Thanks
Update: I've been recommended 15mm on the back and 22mm on the front which is what this R34 is using (although on 225/40/R18 tyres):
http://imgur.com/y4rFwgt
What do you guys think? Will 235 be ok?
Yes, 235 will be fine.
If you are concerned about legality, I would go for the +22. The 15 will be a fairly aggressive fitment and assuming you are not lowering the car. I have 9.5+20, which is close to your 9+15, and my rims poke both front and back, even with camber.
Thanks for that.
More concerned about aesthetics than legality to be honest... haha. I think the picture above might be 15mm at the back and 22mm at the front however, doesn't look like it pokes out too much?
Thanks for that.
Depends on what angle you look on. Here is 9.5+20, with some camber. Don't get me wrong, I wouldn't change my offset for the world, I think it is perfect, but the cops wouldn't like it that's for sure. If you're only worried about form, go for it. You could run +15 all round if you wanted to. It's pokey, but not mexican.
Edited by sleptema
I attempted to use search for this, but it came up empty.
I searched for a known size, still naught.
Don't think it likes numbers.
So........
Anyone know/ have pics of 18x10.5 +22 on a 32 gtr?
How close are we going to get to guards, suspension?
That front one is deceptive though. You can easily pull the front guards out enough to reduce the poke.
I had 9.5+12 up front with no flaring and less poke than that :)
  • Like 1
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
