Wheel Sizes & Offsets For Skylines
Hey guys,
been looking through this thread and other forums for ages trying to decide on a good wheel fitment for an r33 s2 gtst. Seems like 18x9 +20 would be a decent fit for an r33 all around flush fitment that wont foul suspension and can be cambered in to prevent scrubbing on guard liners. Have seen examples of this size in a set of work xd9s (dontyellpl0x) and a set of rota grids (boosted_andy). Would consider anything similar to 18x9.5+30 but it seems that at this wheel size its a bit hit and miss whether or not it will foul suspension/brakes. What wheels are still being made in 18x9+20 (grids and xd9s/d9rs not available in this size anymore) or 18x9.5+30 which dont foul brakes? Dont want to mess with spacers.Want to run 235/40 all around. All guards already rolled ,dont want to bin guard liner.
Cheers guys.
Edited by onthesuss
  • Like 1
Hey guys,
Cheers guys.
9.5+30 will fit.
Will the car be low? If so you are better to lip the front guards
Hey guys,
Cheers guys.
235 is too small for 9.5 and marginal for 9in.
Hi guys,
I'm looking to pickup a set of these wheels in 18x9 for my R34 GTT:
http://marsperformance.com.au/MARS-MP-37-4x-18-Inch-Matt-Bronze-Alloy-Wheels-Rims-5-x-1143
I don't believe the car is lowered and I would prefer to not roll the guards. These are the tyres I'm looking to fit:
https://www.tyresales.com.au/buy/tyre/kumho/ecsta_le_sport_ku39/235-40r18/1383?q=4
The offset available for the wheels is 15mm and 22mm.
What wheel sizes should I order in order to get a flush fit without having to roll the guards? Will the 235/40/R18 also fit properly?
Thanks
Update: I've been recommended 15mm on the back and 22mm on the front which is what this R34 is using (although on 225/40/R18 tyres):
http://imgur.com/y4rFwgt
What do you guys think? Will 235 be ok?
Yes, 235 will be fine.
If you are concerned about legality, I would go for the +22. The 15 will be a fairly aggressive fitment and assuming you are not lowering the car. I have 9.5+20, which is close to your 9+15, and my rims poke both front and back, even with camber.
Thanks for that.
More concerned about aesthetics than legality to be honest... haha. I think the picture above might be 15mm at the back and 22mm at the front however, doesn't look like it pokes out too much?
Thanks for that.
Depends on what angle you look on. Here is 9.5+20, with some camber. Don't get me wrong, I wouldn't change my offset for the world, I think it is perfect, but the cops wouldn't like it that's for sure. If you're only worried about form, go for it. You could run +15 all round if you wanted to. It's pokey, but not mexican.
Edited by sleptema
I attempted to use search for this, but it came up empty.
I searched for a known size, still naught.
Don't think it likes numbers.
So........
Anyone know/ have pics of 18x10.5 +22 on a 32 gtr?
How close are we going to get to guards, suspension?
That front one is deceptive though. You can easily pull the front guards out enough to reduce the poke.
I had 9.5+12 up front with no flaring and less poke than that :)
  • Like 1
    • Updating results.  Using ATR45SS-0 model VS UHF57-900. Those two are very different turbos, different wheels sets with different wheel hub profiles but yet with almost identical result. I’m intrigued with both turbos performance. ATR45SS-0 was a 61mm turbo first developed in May 2020, UHF57-900 was a 62mm turbo developed in March 2024 as a powered up alternative of a G30-900. On paper ATR45SS-0 maxed at 563rwkws, while UHF57-900 maxed at 568rwkws. ATR45SS was slightly more responsive with slightly better power band through the mid range.  Road driving ability, ATR45SS-0 had better throttle response, felt more robust under throttle, as it wakes up earlier. I think G series wheel hub design made it to have higher inertia under light throttle. Doing bit more prototype work in the next few weeks, will update result when its back on dyno again. ATR45SS0 Blue, UHF57-900 Red Chequered tuner's Dynapack hub dyno, E85 fuel. Mod list is in video below video_20240604_114214.mp4
    • Did you run the power cables for the mac valve to the other side of the car near the fusebox? Utilizing the stock boost controller cables? or did you run new ones?
    • Hey I have a potentially stupid HICAS question 🤣 I'm currently doing a full hicas delete, Power steering pump modified to non hicas, all lines removed from the car along with all electronics. My stupid question is - Do I need a lock out bar? is there any reason why I cant just remove everything from the rear end? I already have a lock out bar but thinking to save a few extra grams I could also get rid of the arms and tie rods as well and just run it with nothing in its place? or would it have a negative effect on handling?
    • Hi how are you guys?  I know i have been absent for years but im coming back slowly guys just wondering if anyone know where the ball joint on the NISMO arm front and rear can be replaced with OE parts?  Also  i know this is not the thread looking for springs and blistein shocks for the 260rs. Please advcie     cheers    yudy
    • Hi i do you have for stages 260rs?
