I'm currently looking at a new set of Rims for my R33 if anyone is interested in my staggered fit chrome 5 spoke style 19x7.5 front-19x8.5 rear (spacers for caliper clearance provided) with decent tread on them let me know. but to my main purpose of this post.
i am getting a set of Koya drift tech rims for my car. i will be putting slightly bigger brakes on my car eventually, if i get a set of 18x8.5 all round with a 30p offset does that seem like enough clearance for bigger brakes and also will they scrub badly on the front at full lock?? any advice would be great and no i don't want to go a staggered fit as an ex tyre fitter different width rims is just impractical for tyre life
Hamish or other knowledgable people.
Lot of talk here regarding 18x9+30 in the front of a R34 GTT or GTST. GTR Rims, sizing etc.
Lot of people run thin tyres on them, which 'fit'
Can you fit a 265 tyre on a 18x9+30 rim at the front of a 34 GTT?
Does it need guard work? Does it scrub? Etc etc.
Basically want the most tyre I can fit in there.
For bonus query, I plan to run about -3deg camber at the front, and have about 355mm center of wheel to guard.
/shake fist at all you tyre stretching people skewering results.
Let me know how it goes. I just bought track rims 18x9.5+22 255/40 and am yet to test fit. Would like to know what kind of issues (if any) you have with yours.
I mocked it up and it SHOULD fit.
that will fit. you will need to pull the guards a little, but not flare by any means
Looking for size and offsets to fit an R34 gtt 50mm rear fender wide body if anyone's accomplished this?
Thinking 18x11+18?
Also what's the best for pumped front guards? 18x9.5+20?
I'm probably way off.. haha..
Edited by Swole
ok... so i hate to ask this but i need some fine tuned answers from people who know more than me or have tried.
will these work on an R32gtr
18x10.5, +17 and +21
im currently running 18X9.75+20
the existing tires are 265-35-18 and im going to run them again.
i know it will be a little stretched but cmon not allot. and they will fit the guards a bit better without too much camber.
current setup looks like this.
from my calculations they will not get too mad.
in my eyes its gonna fit fine.... but when i look at 10.5 and r32... it dosnt seem like it should.
do you think i will need to roll the guards? i already know my inner liners will probably need to be removed as they DO scrub on hard cornering with the current setup. but the top of the tire will not actually move... hmmm
thoughts?
these are the comparisons.
First of all I think your current set up looks pretty good. The 265s will be not ideal but OK on 10.5 tyres but with virtually the same offset do you have enough clearance on the inside under cornering? Your outside guard might need a little massaging but not too much.
Ill get under the car and see if 10mm close to the strut will become an issue.
Their a front and rear set and the offset is what it is so i dont get to choose.
I do like the xxrs but their not what is staying on the car. A set has come up which are more my style.
Thinking 18x11+18?
Rears will be an eeeeeeeasy fit. A little inside the guards
Fonts will need a roll only
  • 3 weeks later...
Skyline model = R33 GTS-T
Wheel diameter = 18"
Wheel width = 9"
Wheel offset = +27
Tyre size = 245/40
Modifications to fit = Rolled guards
Hello, thanks to all the great information on here I have finally decided on my setup. IMO this is perfect, I really wanted to get the same width and offset rim all around so the concave would be the same. If anyone is interested they are Rota Boosts in Gunmetal. Here are some pictures.
Thanks :cheers:
Edited by CarterIvy
  • Like 2
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
