I'm currently looking at a new set of Rims for my R33 if anyone is interested in my staggered fit chrome 5 spoke style 19x7.5 front-19x8.5 rear (spacers for caliper clearance provided) with decent tread on them let me know. but to my main purpose of this post.
i am getting a set of Koya drift tech rims for my car. i will be putting slightly bigger brakes on my car eventually, if i get a set of 18x8.5 all round with a 30p offset does that seem like enough clearance for bigger brakes and also will they scrub badly on the front at full lock?? any advice would be great and no i don't want to go a staggered fit as an ex tyre fitter different width rims is just impractical for tyre life
Hamish or other knowledgable people.
Lot of talk here regarding 18x9+30 in the front of a R34 GTT or GTST. GTR Rims, sizing etc.
Lot of people run thin tyres on them, which 'fit'
Can you fit a 265 tyre on a 18x9+30 rim at the front of a 34 GTT?
Does it need guard work? Does it scrub? Etc etc.
Basically want the most tyre I can fit in there.
For bonus query, I plan to run about -3deg camber at the front, and have about 355mm center of wheel to guard.
/shake fist at all you tyre stretching people skewering results.
Let me know how it goes. I just bought track rims 18x9.5+22 255/40 and am yet to test fit. Would like to know what kind of issues (if any) you have with yours.
I mocked it up and it SHOULD fit.
that will fit. you will need to pull the guards a little, but not flare by any means
Looking for size and offsets to fit an R34 gtt 50mm rear fender wide body if anyone's accomplished this?
Thinking 18x11+18?
Also what's the best for pumped front guards? 18x9.5+20?
I'm probably way off.. haha..
Edited by Swole
ok... so i hate to ask this but i need some fine tuned answers from people who know more than me or have tried.
will these work on an R32gtr
18x10.5, +17 and +21
im currently running 18X9.75+20
the existing tires are 265-35-18 and im going to run them again.
i know it will be a little stretched but cmon not allot. and they will fit the guards a bit better without too much camber.
current setup looks like this.
from my calculations they will not get too mad.
in my eyes its gonna fit fine.... but when i look at 10.5 and r32... it dosnt seem like it should.
do you think i will need to roll the guards? i already know my inner liners will probably need to be removed as they DO scrub on hard cornering with the current setup. but the top of the tire will not actually move... hmmm
thoughts?
these are the comparisons.
First of all I think your current set up looks pretty good. The 265s will be not ideal but OK on 10.5 tyres but with virtually the same offset do you have enough clearance on the inside under cornering? Your outside guard might need a little massaging but not too much.
Ill get under the car and see if 10mm close to the strut will become an issue.
Their a front and rear set and the offset is what it is so i dont get to choose.
I do like the xxrs but their not what is staying on the car. A set has come up which are more my style.
Thinking 18x11+18?
Rears will be an eeeeeeeasy fit. A little inside the guards
Fonts will need a roll only
  • 3 weeks later...
Skyline model = R33 GTS-T
Wheel diameter = 18"
Wheel width = 9"
Wheel offset = +27
Tyre size = 245/40
Modifications to fit = Rolled guards
Hello, thanks to all the great information on here I have finally decided on my setup. IMO this is perfect, I really wanted to get the same width and offset rim all around so the concave would be the same. If anyone is interested they are Rota Boosts in Gunmetal. Here are some pictures.
Thanks :cheers:
Edited by CarterIvy
  • Like 2
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
