Just read through this thread on aus300ZX and was wondering if any/many SAUers use it?
Is this about the right price ($100 for serial cable, software additional)?
Does the novely factor wear off? It looks like it'd be great to check the engine/ECU but it also seems to be one of those things you'd just like to borrow from a mate twice a year.
Is Datascan the best software available for it? I vaguely remember a recent post where a guy was replacing an R34 O2 sensor and a few freeware versions of the software were mentioned.
Cheers
I was looking at this as well, i'll check out doodz's one next saturday and make my decision from that..
looks good though, would be nice if there was some better software from my thoughts.. the analog system doesn't look the best..
You can map it with different systems, but real time is the greatest..
Other option is to get an R34 MFD and wire it into the ECU.. found a couple of links on how to do it..
not at all, in fact the display is great, 12 analogue guages on the screen with digital numbers as well. And of course the outputs you choose are configurable :(
You can also turn off coils individually etc as well
I just purchased the Software and the USB cable the otherday, waiting for it to arrive now. Hopefully it might shed some light if there is anything wrong with my engine.
It looks like a handy diagnostic tool.
Edited by Endorean
It's fun to use for a while and good to have if there are problems to diagnose.
The displays are quite cool, and the data logging is interesting.
It's cheap so I got one, not much more to say really.
What model Skylines have an OBD1 port?
Thanks for the replies guys.
Duncan: I just don't trust the engine yet and after Links refreshed my memory, I'm pretty sure doodz suggested Satanic (man this sounds like days of our lives :D) check the ECU before going and spending money on new O2 sensors and AFM's etc.
It's just one of those things I'd like to run once, see what the software has to say about all the bits and pieces on my *genuine!:) * 70,000km engine. I'd just like to know it's all working properly cause the idea of a rebuild is scary and financially out of reach for the next 12 months.
If I took the car to UAS to have it checked it'd probably cost the same to buy the cable and run it on my own laptop...
i got one of these through impakt on these forums:
http://www.skylinesaustralia.com/forums/in...ic=42617&st=200
work good, all i really wanted was water temp but for the price its pretty good :)
works on my chipped RB20DET and pretty much any skyline.
Thanks Mickroy, that's exactly why I'm thinking about buying one. Every time I plant my foot the exhaust belches black smoke and fuel economy is around 17L+/100km on the highway. Cheaper to buy the cable rather than pull out the O2 sensors just to find out that wasn't the problem.
I don't yet trust my engine and I'd like some confirmation that everything is functioning properly! :P
Cheers dude
i need one of these. where can they be purchased from? im looking at the blazt website and it states that there are distributors in australia, Caroline Felgate (nsw) & Rob Armour (qld). anyone bought off them before?
I don't yet trust my engine and I'd like some confirmation that everything is functioning properly! :huh:
Cheers dude
Does sound like the o2 sensor.... it should only have a 0-1v range, and its easy enough to check the voltage if you've got a pin out diagram for the ecu, and of course someone to check it while you're driving. I basically bought the cable coz i was lazy... but its great to have there for when things do go wrong. Chances are you'll be able to work it out in 5 mins, rather then days of rooting around with a multimeter... dont rely on ecu diagnostics to tell you the prob either... I can unplug all my sensors and it wont spit up an error coad.
My sensor was stuffed... the ecu seems to get a constant 3v if it cannot communicate with the sensor. The rb25 manual stated this, and was right... it showed constant 3v, even when i unplugged the sensor, 3v came up as the sensors output! So it was pretty easy to find :P
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
