  • 3 weeks later...
Sorry for digging up an old topic,
Looking at buying a set of 17x9+24 with 215/45r17 tyres for my my series 2 auto.
From having a read through I'm sure the fronts will fit fine and rears may need the guards rolled/lipped?
Thanks
Thanks
They should fit fine, but you should roll your guards anyway. 215s are a bit narrow for a 9" aren't they? (Personally, I'm not a fan of the stretched tyre look.)
Hey guys. Anyone know how I would go for fitment on a c34 rs4s stock suspension. With a 18x9 +12 with 265/35s
These should fit fine too, the RS4S has a narrower rear track than the factory auto. Once again, as per above, roll those guards - 265s might be cutting it really close. I've got 245s on 18x8+30s and there's only about 5mm room.
So I have some 350Z rims fitted to the series 2 auto Stagea - fits well except the front track is narrower than the rear causing terrible road handling - hoping that fitting some 20mm bolt on spacers to the front may help - any oninions? Here are the specs -
Fronts - 18 x 8 +30 running 245/40/18
Rears - 18 x 8.5 +33 running 245/40/18
Here's another person asking for answers!
My incoming m35 has a set of Venerdi 19" 5 spoke chromes on it that I WILL NOT be keeping. (read.. for sale!)
there's so much variation in preferences and all that for tyres and wheel size, offset, width etc.... all I want to know is...
What wheels do I get so that they fit with NO modification.
they will likely be:
19" x width<?> offset <?>
currently wearing 245/40x19"
HALP!
HALP!
19x9 +30 offset would go on no mods; 19x9.5 +22 offset would require light guard lip rolling.
And look 5000 times cooler.
Cheers Daleo, um.. i'm a massive noob.. WTF is guard rolling? is it like flaring the original guard instead of bolt-on (like axis etc)?
Is the max width without rolling, 9?
Seems like there's much less 9 than 9.5 out there. Wish I understood the offset mumbo a little better to make a good call.
I'm thinking about some of these... Haven't got much cash to splash on wheels and tyres.
http://www.ebay.com.au/itm/Rota-GRID-19-x-9-0-20-5x114-3-/150664390583?pt=AU_Car_Parts_Accessories&hash=item23144c27b7
Edited by Kazal
Ok I've just read this entire thread and I'm probably more confused than when I first started...
I have a manual RS4S (series 2) with BC coilovers. At the moment I have Enkei NT03M 18 x 9.5 +27 (with 15mm spacers in the rear; so +12) Tyres are 235 45...AND I still scrub on the coilover in the rear. Going straight is fine, it's mainly bumps, hard corners and heavy offloading onto the back (front is fine)
SSOOO...I'm look at getting some new wheels. 18 x 10, what are people's opinions on offset to sit at least flush with the guard?
Just looking at opinions as I have found a couple of pretty low offset wheels...
Thanks for any help in advance!
- stix
Type 'Rota failure' into Google for me, this is why I generally prefer OEM or forged rims. They will probably be fine though, and the size is about right.
I ran 9 inch + 30 17's without issue, yours would stick out a little at the front as they are 10mm further out.
To get the wheel to clear you may have to roll the guards, which involves using a machine bolted to the hub to roll the lip in and push the guard out a little, especially at the top. You need to heat the paint at the same time or it can crack easily. It's not something many people are willing to do themselves, best off getting some quotes from a professional.
Haha Scotty, I have seen all that, there's about 5 images.. and then 50x12,000 copies of the same ones.
As I understand it, Rota make about 1/3 of the OEM wheels in the market anyway....... So.. interesting that you would say you prefer OEM (I believe ENKEI are responsible for much of the OEM market also).
In other news, what about the Varrstoen wheels?
This car is a daily and being held for eventual resale value mostly. It will probably not ever see a track so I'm not chasing performance wheels, just a pretty fit.
i would swap them the other way! your stagea will loose front grip before it looses rear and in favor of wider rear track on stagea
Everything I've heard about them, they appear to be good quality, very well finished, and stand up to trackwork pretty well.
For a copy of someone elses intellectual property. I'd go for them over Rota's to be honest.
Several Stagea owners have them fitted; maybe check the thread. http://www.skylinesaustralia.com/forums/topic/325613-m35s-wheels-what-wheels-do-you-like-on-your-m35/
The search function is quite useful. ;)
BMW owners seem to be wary of Varrstoens, can't comment on the quality myself though. I suspect that like any other "replica" wheel people will have had good and bad experiences. Yer pays yer money and takes yer chances.
Edited by Hertz Donut
So, you guys are saying that any wheels that cost less than about $2k a set are all just copies, and the quality is (potentially) questionable? Sheehs!
Now I REALLY wish my Stag had OEM's on it.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
