R34 GTR non V-Spec
Apexi Power FC
Apexi Air Filters
Greddy Profec B-Spec 2
Nismo Air Flow Meters
Nismo Radiator
HKS GT Intercooler
HKS 2530's
100mm Catback Exhaust
Impul Front Pipe
Sard 650cc(i think) Injectors
Sard Fuel Regulator
Walbro Intank Pump
Tomei Type B Poncams
Tomei Cam Wheels
Tomei Manifolds
Tomei Dumps
Tomei Fuel Rail
314kw atw on 18psi on first tune.
Hypertune intake manifold and single throttle body installed, retuned and now making 360kw at 18psi. Still stock bottom end :)
89 GTR
33gtr crank
standard rods and pistons
N1 water pump
N1 oil pump
x force dumps
unknown front pipe
apexi cat back
apexi pod intake
sard 650 injectors
040 pump
garret/hks 2530s
port matched inlet - exhaust
adjustable cam gear
pump and afms run out of puff at 265kw on 16psi, lots more to come soon.
Edited by robbieraver
  • 4 weeks later...
89 r32 gtr
apexi pfc+hc
hks split dump, bee-r front pipes, highflowed cat
trust 300+600+100mm cooler
greddy cam gears
hks pods
exedy heavy duty clutch+lightened flywheel
made 241awkw@7177RPM and max M.A.P OF 203.8KPA@7080RPM (TUNED AND DYNOED BY PROTEK AUTOMOTIVE ON BP ULTIMATE FUEL)
soon to go in are bosch z32 afms, nismo 600cc injectors, tomei 260deg 9.15mm lift cams, will get results and dyno sheet up asap
Edited by GTRBOS
  • 1 month later...
R34 GTR V Spec:
HKS front pipe
HKS cat back Hi Power system
HKS pods
Made 215.1 awkw @ 7000RPM 0.9 BAR Boost
IS Motor Racing Dyno
In a few weeks time, adding Nismo fuel pump and fuel pressure regulator, HKS EVC to bump the boost up to 1.2 Bar.
Will post up results of these when done.
Cheers
94 R32 GTR
Rebuilt standard turbos with steel exhaust wheels and 360deg thrust bearings
Nismo 600cc injectors
Nismo fuel Reg
Bosch 040 pump
Apexi PFC
Greddy Profec B II Boost controller
Adjustable cam gears
HKS Pods in custom air box
Trust front pipes
Hiflow cat
Trust Cat back exhaust
Engine internally standard
Standard items: Intercooler, manifolds, dumps, coils, afms.
Dyno: Dynopack 4 wheel hub dyno.
Result: 281 4wkw and 472nm @ 18psi
VEHICLE: 1989 GT-R
ENGINE: RB26DETT, 88mm bore, CR=8.7:1
MILEAGE: 127xxx Kms
OIL/WATER PUMP: Nismo/OEM
OILING SYSTEM: Tomei Orifice, Tomei pan baffle, Greddy oil cooler and filter relocation
INJECTORS: 600cc Nismo
FUEL SYSTEM: Bosche 044 in-tank
TURBO SETUP: twin GT2860R-5
MAP or MAF's: MAP
INTAKE SETUP: Apexi Power intake
INTERCOOLER: OEM
VALVETRAIN: JUN 264/264 9.7 mm lift - adjustable gears
HEAD WORK: Intake mildly ported and left rough, exhaust opened up about 15% and polished, combustion chamber polished
EXHAUST: HKS dumps, Tomei DP, 85 mm HKS Priest
BOOST LEVEL: 1.2 bar = 17 psi - Blitz Dual SBC Type R
ECU SETUP: ViPEC Speed Density
Nice conservative tune intended to let me have a ton of fun without making rebuilds my hobby.
HP: 390
TQ: 330
r32 gtr
v Spec 80k
Garret 2860r-5
trust dump pipe and nismo rear exhaust
nismo afm
power fc
nismo injectors and pump
otherwise standard
300kw and 730 Nm at the wheels
20 psi max boost with safe air fuel ratios
BNR32
Garrett 25/60r Turbos
Power FC
Sard 660cc injectors
Bosch 040 in tank fuel pump
Apexi air pods
(Standed turbo pipes and cat).
Low Boost 14psi made 268kw High Boost 18psi 297kw .
Edited by Rav
ported head matched manifolds
jun guilds stano vavles
stock cams
stock cam gears and springs
baffled sump oil restrictors in the block cam cover plates
jun collar and oil pump
acl race bears mains and big ends
rev rods
cp pistions
1.3mm metal head gaskit
metal inlet manifold gaskits
pfc
stock cooler
stock inj stock fuel pump
stock air flow meters
stock dump pipes
front pipes 3 inch cat 3inch exhuast and cannon
stock turbos
os giken twin plate clutch
eboost 2 set to 13psi
262rwkw!!! 351hp
i was very surprised! can not thank anth enough at turbotechics more responce every were! and better on fuel! :D
PHA71L
new pb of 12.046 181.23kmh 60 foot 1.701
  • 3 weeks later...
Gday,
Just got my car tuned after being off the road for about 3 years. Ive put an RB26 engine (and an R33 gearbox) in an R32 gtst. The tune is a preliminary one, so ive gotta run the car in and go back in about 1500kms so they can turn the boost up.
The car made 345 rear wheel kilowats on 17 psi and 98 octane. There should be more to come, but after driving it home from Silverwater in the wet, im not sure more power is a good idea in a rear wheel drive application!
The specs are as follows:
R33 RB26 (prepped block etc, compression is 9.0:1)
ARP head studs and rod bolts
General head reconditioning but no porting or polishing
Standard cams
HKS cam gears
CP Pistons 20 thou over
Prepped standard rods
N1 oil pump
Tomei sump baffle and head oil restrictor
R33 gtst 5 speed
Jim Berry modified Nismo 5 puck clutch
Autronic SM4 computer
Autronic boost control
Garrett GT35r turbo with 1.06 turbine housing HPC coated
Tial 44mm external wastegate with 17psi spring
Tial 50mm BOV
600x300x100mm intercooler
Earls 16 row oil cooler
Stainless manifold bought from GCG. Modified with extra support brackets and HPC'd
3.5inch dump, HPC'd and wrapped
3.5 inch custom exhaust thats really quiet.
Walbro in tank pump (255l/hr i think)
Surge tank with Bosch 044 in line (i also used the HICAS lines as fuel lines)
Sard 700cc injectors
Edelbrock fuel reg and modified standard fuel rail
Ford falcon twin thermo fans with 50mm alloy radiator.
I think thats it.
Just gotta get it engineered and registered now.
Shaun
Just to update, i got the final tune done yesterday and had the closed loop cruise initiated. The car made 350.5rwkw @ 17psi, but more importantly, i gained 76Nm of torque which is really noticable on the road. The old and new dyno sheets are below.
Im pretty happy with that,
Shaun.
Edited by Shaun
Engine
HKS step1 camshafts 264/272
HKS adjustable camgears
HKS inlet manifold gasket
Gates timing belt
cometic head gasket
custom P20 tool steel heat treated billet CNC machined oil pump
R33 RB26 crank shaft
external oil return lines from cylinder head to sump
Garrett GT35R Ball Bearing turbo (A/R 70 compressor housing with anti surge . A/R .78 Divided exhaust housing)
TiAL 44mm external wastegate
screamer pipe
custom steampipe Manifold to suit divided turbine exhaust housing
custom dump pipe + front pipe
hi flow 3inch cat
X force cat back exhaust system
115mm intercooler
custom aluminum intercooler piping
custom intake pipe
custom air box
greddy blow of valve
custom catch can
aluminium radiator
VEHICLE: 1990 GT-R
ENGINE: RB26DETT
OIL PUMP: N1
INJECTORS: Standard
FUEL SYSTEM: Walbro 500HP
TURBO SETUP: twin GT2860R-7
MAP or AFM's: Standard AFM's and MAP
INTERCOOLER: OEM
EXHAUST: GCG dumps, Veilside 3.5" exhuast and front pipes
BOOST LEVEL: 1.2 bar = 17 psi - G-Reddy Profec B Spec II
ECU: ViPEC V66
  • 3 weeks later...
VEHICLE: 1991 GT-R
ENGINE: RB26DETT
MILEAGE: 3780 Kms
CHASSIS MILEAGE: 78xxx.xx
OIL PUMP: N1
WATER PUMP: N1
OILING SYSTEM: Tomei pan baffle, Greddy oil cooler and filter relocation
INJECTORS: 550cc Nismo
FUEL SYSTEM: Standard R32 GTR pump
TURBO SETUP: twin Trust T517z
MAP or MAF's: Nismo AFM
INTAKE SETUP: Standard - Apexi foam filter
INTERCOOLER: Trust/Greedy 300+600+100mm cooler
VALVETRAIN: Standard camshafts - Old Skool HKS adjustable gears
HEAD WORK: Mild port n polish to just linish any burrs only.
BLOCK WORK: Cryoed and preped block, HKS 2.6 Billet crank, Trust/Carrillo Conrods, Weisco Forged pistons
MISC ENGINE PARTS: ACL race bearing, mains and big ends, Tomei headgasket, Racepace Radiator
EXHAUST: HKS front pipe, Racepace manifold, 90 mm HKS Dragger
BOOST LEVEL: 20 psi
ECU SETUP: Apexi PFC
320.1kw @ RACEPACE
1996 R33 GTR Vspec
Tomei 260 Poncams
Tomei cam gears
Splitfire DI coilpacks
Sard Fuel reg
reco'd stock fuel rail
Apexi PFC
Greddy Profec E-01 EBC
Bosch 044 fuel pump
Greddy front pipes
High flow cat
Greddy 3" power extreme II exhaust
Grex oil filter relocator kit with remote oil cooler
100mm FMIC
KKR hard piping kit
Stock air box with K&N panel filter
Stock turbo's
Stock dumps
Stock engine internals
OS Giken twin plate STR clutch
Stainless Oil sep/water bottle system
As you can see, plenty of old fashioned dyno shake which hampered performance slightly.
235 awkw @ 15psi with a projected output of 280rwkw with the front driveshaft disengaged.
This is a peak torgue tune from ADVAN Performance specifically for track/street with the 15psi boost threshold being reached at 2800rpm.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
