1993 Nissan R32 GTR
Apexi Power FC
Trust Front Pipes
X Force 3.5" Hi flow Cat
Veilside 3.5" cat back exhaust
Greddy Profec EBC b spec II
HKS adj cam gears
Standard Turbos
low boost: 12psi - 209kw (at all 4 wheels)
high boost: 14.5 psi - 233kw (at all 4 wheels)
Cheers to Adam and the team at Just Engine Management
  • 3 weeks later...
1992 R32 GTR
Unopened motor - 180,000klms
Splitfires
Garrett -7 turbs
Tomei adj cam wheels
R34 GTR dumps
G-Reddy Profec B II EBC
Nistune
Blitz 70mm - 80mm front pipe
Std Nissan Cat
Some sort of Jazma cat back
285RWKW @ roughly 18psi. Dyno chart attached.
Very nice set up it is too. Thanks to Status.
1382_001.pdf
-Forged Pistons (wisco)
-tomei Metal head gasket
-tomei Oil pump
-ACL bearings
-New crank
-port and polish
-tomei head restictor
-tomei sump baffle
-New belts
-Engine Blue Printed
2860-5 Turbo's
nismo Fuel pump
700cc sard Injectors
Larger FMIC
HKS Adj Cam Gears (std cams only)
HKS pod filters
custom 2.5" twin exhaust
hks twin plate clutch
power fc
332kws maxed out afm, once upgraded i will be going for 400kw
1994 R32 GTR @ 108,000kms
Before = 205kw
  • Stock turbos @ 11-12psi (up a bit due to the exhaust)
  • Stock injectors & ECU
  • Nismo Ne-1 Exhaust
  • Aftermarket fuel pump (unknown make)
  • Splitfire Coilpacks
  • Stock R34 GTR AFMs
After = 285kw
  • Garrett 2860-7 @ 18psi
  • Nistune board
  • Sard 700cc injectors
  • Tomei sump baffle
  • Mines cam baffles
  • Oil Cooler
  • 52mm radiator
E36 BMW with unopened Rb26
Stock turbos @ 12psi
walbro fuel pump
nismo 550cc injectors
Microtech LTX-12s
450x300x76 intercooler, 3" ally piping
custom stainless dumps/3" exhaust
custom intakes
Tuned by Verun at 101 here in brissy. Really happy he could prove the microtech and RB26 WORK TOGETHER!!
just a crappy bleed valve, actuators opening early hence shite boost curve - will buy a real boost controller soon.
Built by me and my mates in my shed: www.drydenmotorsports.com
1995 R33 GTR
107xxxkms
kakimoto catback
everything else stock!!
First run in red was with boost restrictor pill still in place!!! About 170atwkw
Second run removed, 30atwkw increase pretty good in my opinion!!!!
R33 Gtr block engine been rebuilt, believe it to be r33 head still
unsure of kms and internal modifications
Factory r33 turbos
Pod filters
Exhaust from front pipe back
Stock ecu
Electronic boost controller hks
Walbro pump
7.5psi - 205rwkw
10 psi - 235rwkw
12.2psi 261.3 rwkw
Rather happy with results :P more to gain with an aftermarket ecu and so on
Stoked - 305awkw at just 16.5psi, with a clutch that was only sold as good for 240kw.
24U block, probably N1 engine (so bigger cams, more finely balanced)
Nistune by Croydon Racing
R34 N1 turbos (2860-7s)
Xforce split dumps, modified to put the R32 o2 bung in a sensible location and smoothed a little
Aftermarket front pipe, 200 cell Metal Cat, 3.5 in Trust Cat back (very quiet compared to most)
Greddy Profec EBC
Seimens 550cc injectors
Trust Intercooler, about the same size at stock
Sard high volume fuel pump with direct earth
Adjustable cam wheels (but set to 0)
Otherwise stock, eg airbox, AFMs, coilpacks etc
Jim said it was very easy to tune up and make good power.
Edited by PranK
Fix img url
CP Forged Pistons
CP Piston Rings
Tomei Head Gasket
Tomei Valve Springs
Tomei Valve Lifters
ACL Race Bearing Kit
N1 Oil Pump
N1 Water Pump
Trust Sump & Oil Cooler
HKS 272/280 In/Out Camshaft
Twin Garret 2560's
HKS Fuel Rail
Bosch 044 In-tank pump
Sard Regulator
Sard 800cc Injectors
Autotronic SM4 (MAFFLESS)
Apexi Power Intake Kit
HKS Dump Pipes
HKS Silent Exhaust
HKS Boost Controller
300 AWKW (approx) at 18PSI
328.2 AWKW at 22PSI
Might be making some changes soon, - my target is 330AWKW at 20PSI.
32 GTR
- N1 block
- Jun 2.7 stroker kit (pistons, crank and rods)
- 2860-5 turbos on standard manifolds with HKS split dumps
- 10L sump
- Tomei oil pump
- N1 water pump
- Ross balancer
- full reco head fitted with Grex 264/9.3 cams, Tomei type B valve springs, Tomei cam gears
- Tomei metal gaskits
- 100mm intercooler
- Z32 AFM
- PFC computer
- tuned length stainless front pipes, high flow cat, HKS cat back system
- Sard twin entry fuel rail, Sard FPR, Sard 700's, 2 walbro pumps
I think thats most things.
It made 377 RWKW (Mainline Dyno) @24psi using BP Ultimate. Awesome mid range. :)
Motor built and tuned by Jim at DART Automotive. Very happy with his work.
My setup for the past few years.
1989 R32 GTR
- Unopened standard motor
- Standard injectors
- Standard AFMs
- HKS GT-SS kit
- HKS dumps
- HKS cam gears
- Nismo fuel pump
- PowerFC
- JustJap front pipes
- High flow cat
- Trust PEII cat-back
- Fake woodgrain cup holder
Tuned to 291.4 rwkw on the Racepace dyno @ ~16psi BP98
Motor has finally spun a big end bearing after almost 21 years, Racepace stage 1 motor on the way.
Sydney Kid RB26 build including
8.8 to 1 compression ratio
ACL 86mm Forged pistons
Eagle H Beam forged rods
ARP Rod Bolts
ACL rings
ARP head studs
ARP main bearing studs
600HP Head work
Stainless Steel Exhaust Valves
Adjustable Cam Gears (NOT Dialed in)
Balanced rotating mass
Sump Extension - Extra few Litres with full baffles
HKS 2530 Turbos
700cc 12A Turbo Injectors
Green Label AFM's
Apexi Power FC
Apexi AVCR
K&N Filters
HKS Billet Flywheel
HKS Twin Plate - Rebuilt by Jim Berry
Royal Purple Oil
Ceramic coated exhaust manifolds, turbine housing, front and dump pies
Bosch 044 Race Fuel Pump
N1 oil pump
New cambelt pulleys
Wide oil pump drive flange
Oil flow restrictors
New Cambelt
Block O’rings
370rwhp @ 20psi, not happy... But does feel solid and managed a 100-200 stint in 9.5-10secs. Still, I was hoping for at least 400.
Aaah, RE my previous post with an unhappy 370rwhp, my cat blew out the other night and turns out its a full of a fur like material....?
Anyway, it is now much much quicker, even without a dyno reading I can tell....
Also, been told the dyno I used is around 30rwhp down... so all is well :)
Edited by R31Nismoid
1994 R32 GTR
16x,xxxklms
Performance Mods:
GT 2860R -5's
Tomei Expreme Dumps
Fujitsubo Front Pipes (about 2.75in)
3 inch Decat
Fujitsubo Exhaust (about 3.5in)
ViPec ECU
Tuned by Andy Kuc at Pro Automotive in Hobart
Pushed out 270rwkw @ 17psi on normal Premium Unleaded Fuel (95ron)
Still running standard airbox with airflow meters still in place but not plugged in due to internal MAP sensor in ECU.
Standard Fuel pump, injectors, rail etc.
Still utilising the standard boost control solenoid which surprised us by holding a rock solid 17psi all the way to redline.
Engine has other mods but nothing that will alter the kw it pushes out, just make it more reliable.
This was all done to be as safe as possible so I can drive this car to work every day, take the kids to school etc and still get out and have a go on the track & at the hillclimbes of a weekend. Simply drop in some Ultimate (98ron) as a precaution and away we go.
Mercury Motorsport's R34 GTR
2.8L Engine (tomei)
N1 Block
GCG GT45R
6Boost manifold
Turbosmart 50mm gate
Autronic SM4 with CDI
Splitfire coilpacks
ID2000cc Injectors (6 off)
Magnafuel 750 fuel pump
Magnafuel reg
Hypertune 90mm plenum and throttle body
Apexi 150mm intercooler
ORC clutch
CSR E85 Fuel
Car was 100% built and tuned by Mercury Motorsport
POWER: 940hp on 37psi at all 4 wheels!
Dyno graph to follow....
R32GTS-T RB26DETT
GT2860-5's
ViPec ecu
800cc Sard Injectors
TOMEI 260 Deg Cams
Split Fire Coilpacks
Greddy Adj Cam Gears (set on zero)
Nitto I beam Rods
JE/Nitto 20th piston kit
Nitto oil pump
nitto crank collar
acl main conrod bearings
ARP head stud kit
ARP Main studs
Gates timing belt
Nitto Drag 1.2 head gasket
Jim Berry Clutch
Bosch 044 in tank pump
100mm Intercooler
Greddy Oil Cooler
10L RWD Sump
Rear Oil drain
Stainless Split Dump pipes
Greddy Y Pipe
3.5in exhaust
Tuned by JPC on BP-98 fuel.
First run-in pull at 13.5PSI. Now it needs a fuel system to wind up the boost.
2.6L machined by ADVAN with Head drain, oil restrictor etc
HKS pistons (86.5)
Eagle rods
prepped 33 crank
Trust pump
Genuine Nissan bearings
9L custom sump
Ross balancer
ARP studs
recon head with all new items
Greddy cam gears w/ gates belt
HKS cams (262)
N1 water pump
JJR coil packs w/ HKS twin spark
2x 044 pumps with surge
100mm cooler ... koyo rad ... oil cooler
Garrett T04z (.84) on 6 boost with 50mm pro gate
Link
etc etc
Summer tune little to not timing... Looking forward to winter :happy:
  • 3 weeks later...
1992 R32 GTR - 100xxx Kms
- Standard AFMs
- Standard fuel pump
- HKS Evc 6
- Garret 2860-5's, rear housings ceramic coated
- Trust extension front / split dump pipes with ceramic coating
- Ported standard manifolds also ceramic coated
- PowerFC tuned by Shaun @ Boost Worx
- High flow cat
- HKS unknown cat back exhaust (came with car)
Tuned to 290 rwkw @ 14.0psi BP98
Stock injectors running at 95% :merli:
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
