R34 GTR
Stock turbos
Power fc
OBX front pipes
100 cel venom cat
Apexi N1 GT cat back
nismo panel filter
Blitz spec r boost controller
Splitfire coils
Made 243kw at all fours
17psi dropping back to 16psi
Now 256kw, much cleaner tune thanks to GT Auto Garage
Updated in BOLD
1995 R33 GTR
Performance list:
garrett 2860 -7 running 20psi drops to 19psi
tomei dump pipes
trust front pipe
ballistic cat
nismo catback
1000cc injectors
splitfire coilpacks
bosch 044 fuel pump
haltech platinum pro (mafless tune)
bp ultimate 98
115 Greddy front mount intercooler and piping kit
Greddy air intake kit
280awkw at 19psi
Now 310awkw
300wKw at 20psi on 98RON
R34 GT-R V-Spec II
* -7 Turbos
* 700cc Denso Inj
* Power FC D-Jetro
* Blitz front pipe
* K & N Panel filter
* Greddy DSBC
* Tomei Poncams 260/10.25
* Tomei Cam Gears
* Bosch 044 fuel pump
* Nismo 3" Exhaust
* Hi Flo Cat
Now with 3.5" Kakimoto exhaust
Heya all :)
318kw
Specs:
80000 km old RB26 with 135-140psi compression and already done a Targa Tassie before I got it.
-7s on std dumps
Noname 3" exhaust with hiflow cat
Yellow Jacket coils on copper plugs
Cam gears on std cams
Nismo 550 injectors
19psi
98RON juice
Haltech Platinum Pro w/boost control tuned by HITman (MAP tune, although MAFs were still plumbed up to standard airbox)
Shitloads of blowby!! One 15min session at Wakefield dumped well over 500ml of oil.
Matty (HITman) made this power with the standard airbox, MAFs and snorkel in place. When the airbox was cracked open and a screwdriver handle jammed in there, he saw past 330kw. There's a brand new filter element in there, so contrary to what I've read, my standard airbox was definitely a restriction. Now I just have to bandaid the blowby issue, remove the standard pre-turbo plumbing (MAFs and airbox) and see how long this thing lasts! Hahahaa
This thing idles at 1100rpm on the dot, drives like an EcoTec V6 commo in traffic and will kick you in the nuts when told to. Mid corner throttle/power control is AWESOME and as you can see, the power is quite linear.
Definitely a shedload of fun on a very simple (read: cheap) setup.
HITman, 0417 259 391(Penrith, Sydney)
Mark :)
  • 4 weeks later...
1995 R33 GTR, Stock RB26
R34 N1 Turbos
Apex'i Intakes
Vipec ECU
Catback
Ceramic coated oem headers and turbo outlets
17 psi
383 awhp / 330 lb-ft
Going to upgrade fuel pump, injectors, fpr this winter, new coilpacks, maybe intercooler and fuel rail as well.
first update since owning car :D
1996 R33 VSpec LM Limited
stock turbos
Power FC
Apexi intakes
700cc power enterprise injectors
walbro 550hp fuel pump
HKS silent pro cat back with catco highflow cat
Tomei cam gears
GReddy PRofec B-spec2 boost controller
237awkw or 317awhp @12psi
1993 R32 GTR - 160psi compression across each cylinder
2860-7 turbos
r34 gtr dump pipes
trust front pipes
3" super hi flow cat
3.5" Fujitsubo power getter cat back
NIStune ecu
Sard 280lph fuel pump (14v power supply)
nismo 600cc injectors
Greddy cam gears
M's pod filters
profec b spec II
new coil packs with 7 heat range ngk copper plugs @ 1mm
tuned for midrange punch rather then outright power
low boost - 257rwkw @ 16psi
high boost - 295.3rwkw @ 19psi
  • 3 weeks later...
R32 GTR
ENGINE
built engine
stage 2 hks 272 cams
hks cam gears
TO4Z Garrett
6 boost
48mm turbo smart gate
twin z32 afms
fuel system
sx fuel pump
1450 fuel injector clinic
sard reg
tried running 60% methanol 40% bp 98
managed to pull 560hp at 1.5bar until fuel system ran out of puff, spewin i wanted to wind it up too 26psi. it ran 527 at the same boost on pump but the car does feel stronger through the middle now
will finish of this drum off methanol and give either e85 or a e50/e70 tune a go
Update
630hp at 1.6bar.. e42.5
-Forged Pistons (wisco)
- Eagle rods
-tomei Metal head gasket
-tomei Oil pump
-ACL bearings
-New crank
-port and polish
-tomei head restictor
-tomei sump baffle
-New belts
-Engine Blue Printed
2860-5 Turbo's
nismo Fuel pump
700cc sard Injectors
Larger FMIC
HKS Adj Cam Gears (std cams only)
HKS pod filters
custom 2.5" twin exhaust
hks twin plate clutch
power fc
Z32 afms
running 24psi 381kws
* 2860-5 garrett turbos
* CP forged 86.5mm piston and rings
* Fully prepped block
* Nitto H-beam forged rods
* ACL 1.2mm metal head gasket
* Linished and balanced crankshaft
* Nismo main bearings
* Tomei main bolts and head studs
* Hi-Octane extended and baffled cast sump
* Nitto high-volume oil pump
* Nismo high-volume water pump
* Tomei oil restrictor
* Tomei dump pipes
* Tomei dual layer head gasket
* CRD custom catch can and washer bottle K&N extreme air filters
* HKS 272' 8.5mm inlet and exhaust cams
* HKS cam gears
* Gates timing belt
* 1000cc injectors on Tomei twin entry fuel rail
* Sard fuel regulator
* x2 Bosch 044 in tank pumps
* Splitfire coilpacks
* Haltech Platinum Pro ecu
* HKS EVC 5
* HKS turbo timer
* Nismo thermostat
* Powertune custom fuel intake kit
Exhaust/ Induction:
* Trust titanium cat-back 3.5inch exhaust
* CRD high flow cat
* Nismo weldina front pipe
* HKS 700mm x 302mm x 102mm FMIC
* Cusco oil cooler
(Running 25 Psi on E85)
Edited by Hiroshima Screamer
random breakage 26
gt35/.82 6boost kit
pwr cooler
d jetro
044 intank
700cc inj
stock head + crower v/s and ti retainers
432whp bp98 20psi
haha i got the exact same setup tuned on my car 2 days before you posted this..
Unopened rb26dett (115,000km)
tomei 260 9.15mm poncams type b
gt35 0.82 rear
6boost mani
tial 44mm w/g
700cc sards
stock rail
044 intake
tuned on BP98
485hp @ 20psi on a safe tune (at hubs)
full boost at 4300rpm, love it! shits all over my old twin setup in every way
thick line is gt35 + poncam tune, thin line is -7 tune
Apologies for the poor phone pic of my dyno graph!
Edited by snozzle
Just had my car tuned on Tuesday night
93' R32 GTR
HKS front pipes
HKS gutted 3" cat
HKS super dragged exhaust
HKS EVC 6
Power fc - tuned by steve knight @ skr
Unknown front mount
Unknown dumps
Unknown internals or anything else on the car
Made 244 awkw @13psi dropping off to 12psi actuators are bleeding off and full boost comes on late, any ideas what turbos these could be?
Unknown turbos
this is in my S13 silvia. 594 rwhp on 26psi.
R33 GTR motor
- CP forged pistons
- Eagle forged rods
- Tomei oil pump
- ARP main bolts
- ARP head studs
- ARP rod bolts
- N1 water pump
- 1.2mm oil restrictor
- acl race bearings
- Precision 6765 dual ball bearing turbo/billit front wheel
- precision 44mm wastegate
- custom steampipe exhaust manifold
- cometic metal head gasket
- complete cometic MLS gasket kit
- HKS cam gears
- trust 264/272 cams
- supertech valve springs
- supertech retainers
- motor fully blue printed/balanced/crack tested
- ATI 1000hp balancer
- LS1 coil packs
- 4" stainless dump pipe
- full 4" stainless straight through exhaust
- HKS tripple plate clutch
- indy white 1600cc injectors
- custom fuel rail
- SX racing FPR
- 3x bosch 044 fuel pumps
- walbro lift pump
- 3x proflow fuel filters
- 6 litre surge tank
- 2x -6 fuel lines
- custom 3" stainless cooler piping
- haltech platnium ecu
- 600x300x120mm cooler
- tomei sump baffle
Edited by 26_S13
For everyones information, I have compiled this spreadsheet of all the results from the RB26 dyno thread here:
SAU_dyno_comparisons.xls
This only includes results that aren't from standard turbos.
I hope this doesn't get deleted/moved.
And yes I did get really bored to find the time to come up with this one lol.
Edited by smithy85
Car back from being tuned at JEM (AWD dyno), mods as follows:
Garrett 2860-9's with Garrett 1 bar actuators
Split dump pipes
Trust 70mm into 80mm front pipes
X force 3.5" cat
Veilside JASMA 3.5" exhaust (centre muffler removed)
HKS pod filters
720cc denso injectors
HKS cam gears
Apexi Power FC
Greddy Profec Bspec II
Splitfire coil packs
Std internals
Std AFM's
Std fuel pump
High boost - 287kw @ 18 psi
Low boost - 248kw @ 14 psi (Compare to old standard turbos which made 233kw @ 14.5 psi)
R32 GTR
Pump fuel (98)
Stock bottem end
Precision 6262 plain bearing turbo
Unknown cams (9.1mm lift)
HKS 100mm thick intercooler and piping
Sard 700cc injectors
Power FC
Unknown fuel pump
HKS log style cast low mount manifold
HKS wastegate
4" dump pipe to a 3" cat back exhaust
492hp @ the wheels on 19psi.
New setup;
GT Block
Tomei 2.8 (86.5 mm pistons)
270 @ 10.25 cams.
Nismo Plenum
Nismo intercooler
Tomei dumps
Garrett -5's
Racepace motorsport twin 3 inch exhaust
Link G4 Plug in ECU
Ethanol flex fuel setup
Ross Tuffbond crank trigger. (Timing is no longer taken from the CAS)
Went back to a stock airbox.
United E85
Made 420 RWKW with EBC OFF. (boost spiked at 24 and trailed back to 22.5 psi top end)
More tuning will be done with the EBC on.
On PULP i made 403 RWKW at the same boost. But there is a noticeble difference in how the car drives.
Graph will be up soon.
1994 R32 GTR - probably with 1,000,000kms but 98xxx on the clock
Setup before:
Cat back exhaust
Pod filters
100k service
N1 waterpump
12psi through stock turbos
213awkw
Setup 2 weeks ago:
Garrett -7s
GReddy dump pipes
GReddy front pipe into existing 3.5" exhaust
HKS 264 camshafts
HKS camgears
HKS fuel rail
HKS fuel regulator
ID 1000cc injectors
New fuel pump
Vipec plugin ECU
Eboost solenoid controlled by ECU
Koyo 53mm radiator
320awkw at 18psi with clutch slipping
Track day at Eastern Creek 30/10/2011 - clutch was finished before I even got to the track slipping like crazy from 4500rpm in 3rd and 4th gear. Coilpacks and spark plugs weren't up to the job either.
Setup now includes new clutch, new plugs and splitfire coil packs. High boost tune to come once clutch is run in
Edit: WTF is going on with computers and the internet this morning???
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
