Stock Crank
CP Pistons,
Forged Rods
1.2mm head gasket
100mm intercooler
Tomei Type B Cams
Tomei Cam gears
HKS 25/30s
Tomei Dumps
3.5" Exhaust
Walbro 460L pump
HKS 1000cc injectors
Nismo Fuel pressure reg
Haltech Platinum Pro with Flex sensor
98 @ 20psi 360kw
E85 @ 20 psi 418kw
E85 @ 24 psi 454kw :yes:
Is that 2WD or 4WD, chassis dyno or hub dyno ?
r32 GTR
r33 rb26dett
stock engine
stock turbo's
apexi super dragger 3.5" from from pipes.
some after market front pipe(unsure brand)
apexi avc-r (15psi)
apexi power fc (self tuned)
HKS pod filters
dyno run on 2wd dyno with fuse pulled.
271rwkw @15psi
Sorry about the power colour being hard to see. the little blip at 5000rpm and 7000rpm was coil missfire
Edited by Badgaz
  • Like 1
R32 GTR
Full Nitto bottom end
-7's
Tomei Type B's
ID1000
Power FC
320AWKW@21Psi on 98.
Currently in getting Haltech+E85.... Will report back in a million years when i get the car back.
Edited by Anfanee
  • Like 2
  • 1 month later...
99 R34 GTR Vspec
284.4rwkw.
Unopened motor
-7's
Power FC
17psi
HKS EVC 6
Metal Cat & 3.5 inch Apexi N1 exhaust
Cam gears, Sard 700cc injectors, 19psi and a retune to come in early 2015.
Hoping to hit the magic 300 kw mark
  • Like 2
92 R32 GTR
Head:
Tomei Valve Springs
Tomei guides and retainers
Port and polish
Tomei PonCams Type B
Tomei cam gears
Turbos:
-5's
Dump pipes
3.5" exhaust
HKS hard pipe kit
Mines intake
Fuel/Spark
HKS F-con Pro
HKS EBC
spitfire coil packs
600cc nismo injectors
Nismo race pump
R34 fuel rail
Tomei reg
Bottom end
R33 block
Nissan New crank
Nitto Con rods
Tomei forged pistons
Nismo Rings
Tomei head gasket
Tomei oil pump
Trust sump extension
Twin plate clutch
Results (will pop up dyno sheets soon)
402 ATW KW
370 KW on the road.
GTR-33
Standard unopened engine
Brae high mount manifold
HyperGear HPVA 50mm external gate
1000cc ID Inejectors
Haltech platinum Plug in ECU
HyperGear ATR43SS-2.5 Alpha CBB Turbocharger
600x300x68mm intercooler
3inches turbo back exhaust
330awkws @ 20psi
Pump 98 fuel.
GTR-33
600x300x100mm intercooler (red line on sheet below, the rest was using a 600x300x65mm cooler as above)
337awkws @ 20psi P98 fuel and 367awkws @20 psi E85 fuel:
E85 result
Video:
Same setup as above. Using our high flowed Ebay T67. Final result of 404awkws @ 23psi E85, limitation of fuel pump.
R34 GT-Four with rb26
Forged pistons
Billet n1 pump.
Hks 2540s
Xforce split dumps- hks twin 6mm mid pipe into 3inch exhaust.
Hks 264s 8.7mm with adj gears 1deg adv
Stock gtr intake/airbox
Hard pipe kit.
Z32 afms
Haltech pro.
Just running in it on .8lmbda on boost with 14degrees @17.5 psi 305rwkw untuned. Turned it up to 22psi. Haven't dynod it yet. Should go near 380-400kw once I tune it on e85
Been a few months so far and still goin strong!! :yes:
RB26 S13
STANDARD R34 RB26
N1 oil pump
-5's
STANDARD R34 dump pipes into 2.75" front pipes to 3" exhaust
1400cc injectors
wallbro 460
E85
509HP - 390 RWKW
Best 1/4mile so far 11.0 at 135mph.. on about 480hp... still a rookie at drags haha ;)
http://youtu.be/J0y_oRPFPtg
Edited by BrynDETT
  • Like 1
http://s1068.photobucket.com/user/Ptriffitt/media/866FE882-D5CD-41AE-9988-94F6E6A306B9_zpseiv9vcjy.jpg.html
My 32
This graph was from 2007 with an unopened motor
Stock turbos
Stock cams
Stock injectors
Stock intercooler and pipe work
Adjusted cam gears
Z32 AFMs with APexi filter kit
CES factory style dump pipes and front pipe
HKS super Dragger cat back
Walbro 255 intank
APexi Power FC
Exedy twin plate
R34 GTR VSPEC
Tomei 260 cams + cam gears
Nismo Afm
Power fc
Garrett -5 turbos
Hks suction kit with k&n filters
Catch can
Nismo thermostat
Arc 100mm intercooler
Hks oil cooler
Yellow jackets + Ngk platinum plugs
Nismo twin plate clutch and flywheel
Greddy profec 2 boost controller
Nismo 600cc with walbro 400l
Hks front pipe (2.75-3.5) with venom cat (3.5 with 5inch body) custom 3.5 xforce catback
350kw at 20psi
Edited by R34GTRVJONO
  • 4 weeks later...
GTR-R33
HyperGear ATR45 Special application Turbocharger
411awkws@26psi E85 fuel.
Power and Responds Vs GT3582R on very similar setup:
  • 4 weeks later...
R32 GTR
HKS 2530's turbos
R34 Gtr dumps
Full 3.5" exhaust
Turbosmart Eboost boost controller
Tomei Type B Poncams
Adjustable cam gears
Tomei valve springs
ARP head studs
Splitfire Coilpacks
ID1000 injectors
Twin intake Walbro 255 pumps
NPC clutch
Standard bottom end
403kw @25psi on E85
Edited by France
  • Like 1
R32 GTR
N1 Block
HKS Step 2 2.8 Stroker Crank / Rotating assembly
HKS 272 cams and valve train
Precision 6466 turbo
E85 Flex Fuel
Link G4+
6 Speed Getrag
Didnt lean on it too hard timing wise in the top end, expect to push it a touch over 800 in a few weeks
  • Like 2
Standard RB26
Standard Fuel pump + injectors. Fuel pump direct +12v feed
Turbos either standard or N1's or something. Engine came from an imported R32 half cut so who knows. I'll check what they are when I get a chance. It just made more power than we were expecting
Standard dumps
2x2" to 3" front pipe. 3inch 100cell stainless cat. 3.5" to 4" catback (don't laugh I know it's a shitty design)
Standard ECU socketed and chip tuned by Guilt Toy himself.
270rwkw @ 17psi. 22 degrees of timing in the top end on 98 and it goes super rich from ~7500 RPM to keep EGT's down incase the turbos are indeed ceramic as 17psi is a bit beyond what's considered "safe"
  • 4 weeks later...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
