Yeah, something is seriously odd there.
At least 100hp to nearly 200hp diff to Australian cars.
No wonder the americans love their dynojects and call the dynodynamics the heartbreaker dyno, so they rig their dynodynamics to match the dynojets over there.
Which basically means their figures is no where near what we see here, making it near impossible to make "comparisons".
Edited by s2d4
  • Like 1
R33 GTR
Forged Rb26
CP Pistons
Steel Wheel R33 gtr turbos
Yellow Jacket Coilpacks
555cc Nismo Injectors
Walbro 440lph pump
3.5" catback
Adjustable Cam Gears
Power FC
Tuned By JEZ DVS
254rwkw @17psi on PULP 98
Edited by JDM33R
Well I'll throw in mine for laughs. Run in tune and definitely not the final tune! (fresh motor)
98 octane petrol (flex is coming)
86.5mm Tomei stroker
Type A cams not dialed in yet
4wd dyno & a stinking hot humid day too.
The higher figure is with the factory R32 airbox cracked open to see the back to back restriction it gave. fe53b28e70a45adc2278b36b97c15781.jpg
Edited by mr skidz
  • Like 1
I would be happy to have my car on an american dyno
We can debate this shit forever or your buddy can take the car to the drag strip and see what mph he traps and then if it checks out people here may become believers. My 2c bud.
  • Like 1
How you achieved 760 to 780 engine horsepower is beyond anything I've ever witnessed or believed was possible.
From memory 5's run right outta puff at about 360hp each at around 2 bar. Your running less boost and tiny injectors but are able to find 40 to 60 hp more?
I reckon theres a sneaky 70hp wet shot thrown in there just quietly.
Edited by mr skidz
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
