Thanks for reply. That’s great result. What power it made on what psi? I’m looking for get 8374 iwg or 9180 iwg. But no result I can find.
Search my posts they are all on here including the build thread. 8374 is an incredible turbo for rb26
14 minutes ago, WantGTR said:
No dyno sheet but car went 10.8@140mph. First and only pass.
2018-07-05_07-22-172018-07-05_07-22-44
Nice!  To be fair, this is a dyno result thread and posting a time slip but still no dyno sheet makes baby jesus cry.  Very interested to see the delivery of this
Yes i know. But mph is better than a dyno sheet. Mph doesnt lie.
  • Like 2
maybe just let us know how many rpm full boost?
  • 4 weeks later...
Fresh Dyno
1991 GTR
Stock RB26DETT
Garrett GT2860R-7 turbos
Stock R32 dumps, manifolds, etc.
Greddy downpipe
HKS Super Drager Exhaust
Custom hardpipe intakes (AFMs deleted and all inlet rubber changed to 2.5" Al piping)
Tapped a -6AN fitting into stock fuel rail
FIC 850cc injectors
93 Octane Pumpgas (USA)
BCPR7EIX plugs gapped to .025"
Haltech PnP Rev2 (love this! much better than rev1).
20.5 psig + 3 deg of timing over haltech base.
465 whp
patrick gtr 7-28-18.pdf
On 7/31/2018 at 7:06 AM, HarrisRacing said:
Fresh Dyno
1991 GTR
Stock RB26DETT
Greddy downpipe
FIC 850cc injectors
465 whp
RWHP or AWHP?
465 HP seems a little high for a fairly standard 26 on -7's at 20 psi of boost.
Good result none the less!
RWHP or AWHP?
RWHP.
The car did 384 whp before the stock AFMs cut me off around 17-18 psi...and at 10 psi did about 296 whp. Haltech, cam gears (rolled in about 6 deg of overlap) and intake pipes woke it up. This dyno is pretty dang accurate. Motor runs very well.
Also I just tuned another R32 GTR on stock RB26 on tomei cam gears, 8374 EFR .92 IWG, 6 boost manifold, on pumpgas 93 octane (your 98) and it did 570 whp on 20 psi. Did 636 whp on 23 psi on E30 and ran out of injector. Also on haltech platinum.
Both cars are strong...the -7 car definitely more laggy than the EFR single car though.download_20180806_220847.jpeg
  • Like 1
480kw at 23 psi
Dam bald egles  can tune
This is how that car showed up on stock turbos, stock haltech igniton map and a rough (rich) fuel tune at 15-16 psi. However you want to criticize the overall power, the gains in power are undeniable with only a turbo, injectors, fuel setup, and cam gear changes.
Have a mate with the same turbo at 28 psi e85) and only 380kw
the internal gate bw r junk for bulk power  In Australia
Americans make them sing ( thus the bald eagle comment which after discovering Cletus on YouTube I thought was a compliment)
  • Like 2
Whoa... there is definitely something wrong with that motor if that's all they got out of an 8374 EFR .92 iwg turbo on a stock RB26! I mean how can the iwg be to blame when it's simply a turbine housing that's still in the range of what most choose on the RB if you still stay external? (Referring to the 1.05).
I thought you were mocking me with the bald eagles comment... no sweat there I have a sense of humor (hell yeah brother).
I'll get some videos of the cars this week for y'all
  • Thanks 1
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
