  • Replies 503
Posted Images
I think Duncan does most of Wakefield in 3rd gear. Obviously uo hit 4th on the straight...but i actually shift up from 3rd to 4th a lot more then Duncan, where he just holds 3rd gear.  Well that was in the std R33 GTS25T anyway.
And you the king of the rev limiter. Musta been someone elses car :P
yeah, got to give the limiter some love everynow and then, just to make sure it's still working...lol
snowy, i think OP south circuit would be mostly 3 and 4th in a mildish GTR.
There is footage of me spearing off at turn 2 of wakefield as i quickly pluck what i think is 4th gear trying to do a fancy 5-4 then 4-3 down change...it was actually 2nd ...poor RB20 ;)
It was funny, "this one time, at Wakfield.... i put my car in the mud/dirt that often at the end of the day i had tuffs of grass in the wipers, under the rear boot spoiler" It was a wet day at Wakefield, and with the exception of Duncan and me, there was only one other car on the track (a ute)
It was a good opportunity to lose the car on every corner and convince myself that i am a hack driver and sure as sh1t no drifter :)
Might come down with pom-poms and all and cheer you guys on since its less than an hour away when they finally chose a date... nothing better than seeing skylines give it to everything else... or suck due to crappy drivers... or just blow up, any of the above options work for me though :huh:
Someone mentioned handicap. I can see it now they are going to make me drag an anchor.
Gears at Wakefield. I used to change to fifth down straigth but now on rev limiter just after finish line and hold it then brake just before the kink. V8 Supercars brake well before the kink.
I do ten changes and gear box with big power and high revs is problem sometimes, and miss gears also. Phitzner Dog Box on the list as probably a second or more faster in time with this alone as much faster changing, especially changing up.
Email I received from organiser is extended until end of Feb. Wondering why if they have 400 plus entries as someone said?
Sooo...the date hasn't even been set yet? Good;that gives me time to get my huge sticker kit and 10 inch lowering gear for the 120Y so I'm at least a shot for Hair Salon Sir-Cut Battle Frenzy OMG-thats-fulsik competition...
That was me. I was just hoping there would be handicaps so I have a chance.
It doesn't matter now as snowman mentioned that there will be two classes for race cars and street cars so I doubt you would have to carry weight.
Otherwise to make your car do similar times to mine you would have to put roof racks on your car and strap another car to your roof.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
