Thanks for that. Not sure what to do with the rear seat whether I shoudl cover it in marine carpet or just leave it bare. Same goes for the roof too. Any more shots guys?
Cheers!
Here's a shot of my hks cage with the rear seats in place before painting it, was thinking the same as you should I put carpet or seat back in.
A friend of mine like they head lights you have...
GTS-T light but you painted the surroundings of the lens?
Yeah painted with clear lenses
Get in touch with Risking in the fabrication settion. he is away at the moment. He does about the best half cage you can get. I had a Brown Davis, looked at Bond etc and his cage fits the pillars far tighter and are better made. Not to say the other companies cant do a similar job, but for the money Risking does give you more cage and better quality for what others generally charge a little more. But more then that they are just well made and engineered cages. He is in Sydney but his bolt in cages are all by jig so doesnt need your car to build it if you want to install yourself
Thanks mate, I actually have a half cage installed by Brad, was actually more interested in what people dowith the interior after the cagfe has gone in. My car is completely stripped inside with just a bare metal half cage and seats, so just need some ideas about to what do with all the open space :P
got any shots the back seat area?
not at the moment. not really shot worthy. I have just stripped everything out and taken out the sound deadening
When I am a bit more motivated I will get in there with a heat gun and remove a couple of little bits of stray sound deadening and just tidy some wires that go into the boot and spray the whole area black
I remember in an old SPEED mag, there was an R32 with the number plate "R32" which was basically the inspiration behind what I'm doing with my car. Does anyone know the car or have pics from that mag?
Cheers!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
