Thanks for that. Not sure what to do with the rear seat whether I shoudl cover it in marine carpet or just leave it bare. Same goes for the roof too. Any more shots guys?
Cheers!
Here's a shot of my hks cage with the rear seats in place before painting it, was thinking the same as you should I put carpet or seat back in.
A friend of mine like they head lights you have...
GTS-T light but you painted the surroundings of the lens?
Yeah painted with clear lenses
Get in touch with Risking in the fabrication settion. he is away at the moment. He does about the best half cage you can get. I had a Brown Davis, looked at Bond etc and his cage fits the pillars far tighter and are better made. Not to say the other companies cant do a similar job, but for the money Risking does give you more cage and better quality for what others generally charge a little more. But more then that they are just well made and engineered cages. He is in Sydney but his bolt in cages are all by jig so doesnt need your car to build it if you want to install yourself
Thanks mate, I actually have a half cage installed by Brad, was actually more interested in what people dowith the interior after the cagfe has gone in. My car is completely stripped inside with just a bare metal half cage and seats, so just need some ideas about to what do with all the open space :P
got any shots the back seat area?
not at the moment. not really shot worthy. I have just stripped everything out and taken out the sound deadening
When I am a bit more motivated I will get in there with a heat gun and remove a couple of little bits of stray sound deadening and just tidy some wires that go into the boot and spray the whole area black
I remember in an old SPEED mag, there was an R32 with the number plate "R32" which was basically the inspiration behind what I'm doing with my car. Does anyone know the car or have pics from that mag?
Cheers!
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
