Thanks for the comments guys.
Nice pics, they make me both miss my old NM35 and yearn for my PNM35 lol
Two quick questions though;
1. Single sunroof. Aftermarket I presume?
2. Which car cover is that?
1. Yep, aftermarket sunroof. A Webasto Hollandia 700 fully electric. When I picked up her up from Northshore (it's hard to see, but there's no sunroof in the showroom photo) I drove her straight to Webasto in Kirrawee (opposite GT HIgh Performance) and left it there for a few weeks while they did the install. It usually costs $2k but I paid and extra $1k to get the rolled edge which means they have to respray the roof. It also includes the new roof lining.
web.jpg?ver=13281070800001web.jpg?ver=13281070700001
I guess a sunroof is like a turbo.............you can always add one later. thumbsup.gif
2. The cover is a Kenco Tyvek Medium Station Wagon. I bought it for my R31 but found it fits the Stag as well......just. It's not thick but it still keeps the car body really cool even in the hot sun.
the colour suits her very well too... If you don't mind me saying that your car deserves the white number plates...
Yeah NSW standard plates are fairly ugly. I will be getting personalised ones soon.
Cheers
Nice, I was looking at the Hollandia 300 dual for my old NM35 with a mob down here. They quote me $3.5k including the roof liner so was nice to see the pic of the roof liner!
Thanks for that info, will look into the Kenco cover.
yay for skids.
Whilst timing the short course yesterday at Texi, who gets into the top quarter of best times but Bodella-a-a-a-a !!!!
And Ryan's times just got better and better! Smashing GT-Rs, Sylvias, MX-5s, R31s; Ryan offered no mercy!
Congrats :thumbsup:
Congrats :thumbsup:
Well done Ryan, and was nice to meet you :)
My RS4S.
genuine Takeros bodykit
genuine Takeros carbon bonnet
custom 3" turbo back stainless zaust twin 4" kakimoto hyper mega n1 mufflers
HKS performer coilovers
koya 19" wheels
pod filter...
etc etc lol
got bored today :D
this might be up for sale soon :D pm me if interested...
Edited by OMY31T
My Stagea's first birthday today, stock standard right down to the stereo, she's a keeper.
LOL, that's what mine used to look like!
From this:
To this:
To its current state (except now I also have smoked LED front blinkers and clear side ones):
She's a beauty!, nice shine and interesting seeing the transformation into that lean mean machine. I'm impressed how much ground clearance they have stock, all quite smooth & no lumpy bits hanging underneath. Mine will be staying this way as sometimes there is the need to go into the rough stuff. Looking at the dings & bumps from the last (first) owner it's used to it. They emigrated from Japan & brought the car here.
If my son ever gets hold of my car it'll get modded like that.
Was just scrolling down the page and thought WTF, thats my Stag, But no it was Nicks. Then Bob's came on. If I could I would send a decent pic. The little one in my Avatar will have to do LOL
The first one was Eno's!
Try something like photobucket.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
